Old 11-04-2007, 08:50 AM   #1
space
Shocks bottomed out?
I just realized my rear stock shocks are bottoming out since I replaced the coils with 3" drop coils. I plan on installing these when they come in, will that fix the problem?
http://www.brotherstrucks.com/prodin...number=RGS6372
(2-4" drop under select option)
space is offline   Reply With Quote
Old 11-04-2007, 09:44 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Shocks bottomed out?
Those look like the Doetsch tech shocks that CPP sells. I recently installed KYB Gas Adjusts on the front and love them. I plan to use the same model on the rear. I currently have 4" drop springs but plan to go lower.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-07-2007, 11:00 AM   #3
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
You could flip your lower rear shock mounts, this will make about a 2"-3" difference and stock shocks should work. I did this on my bagged ride and am using stock application shocks (fine with frame on rear end). Take the mounts off, heat and beat down the ridge and bolt to the opposite side upside down. Easy as pie and cheap to boot.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
