flame throwers need help with hei for flames help
can't get it to spark every thing is hook up correct but is for points ign i have hei it is hooked up to the c- side of the coil but does not get spark to plugs in the pipes ? any body help
1995... 2DOOR TAHOE 1999... SUBURBAN 2 WHEEL DRIVE LOW RIDER sold!! 1999... SUBURBAN 4X4 sold!!! 1967...3/4 TON 4X4 SHORT BED 454 sold!! 1972...Cheyanne Super 454 1/2 lwb new toy!! 1972...1 TON 4X4 SUBURBAN CHEVY "RULE" GO OLD SCHOOL!!!!!! ![]() Last edited by mike409; 11-03-2007 at 08:37 PM. |
![]() Join Date: Jan 2001
Re: flame throwers need help with hei for flames help
I'm not sure if I understand the question, but I'm assuming you're trying to get an HEI to work. You need 12 volts at the BAT connection on the cap. The stock wiring has 6 volts going to the distributor, so you'll have to do a little wiring. The coil in in the distributor cap. If you have 12 volts to the BAT terminal and the other terminal from the distributor is plugged into the cap, and the timing is right, it should fire right up.
no sorry i meant flames out the tail pipes it is a kit to blow flames off of raw fuel thanks but i got it lite now did not have anuff fuel going to it had to the choke up it is cool some people use propane big flames
thanks again truckster
1995... 2DOOR TAHOE 1999... SUBURBAN 2 WHEEL DRIVE LOW RIDER sold!! 1999... SUBURBAN 4X4 sold!!! 1967...3/4 TON 4X4 SHORT BED 454 sold!! 1972...Cheyanne Super 454 1/2 lwb new toy!! 1972...1 TON 4X4 SUBURBAN CHEVY "RULE" GO OLD SCHOOL!!!!!! ![]() |
Self-proclaimed LED man
usually the ignition system is shut off after revving up the motor. When you shut off the ignition, the spark plug in the tail pipe is supposed to ignite and burn the unburnt fuel as the motor freewheels before it comes to a stop. Eventually you switch the engine ignition back on and the motor fires back up. Mike, it sounds like you aren't killing the engine's ignition system and it's still burning the majority of the fuel and none of it's shooting out the tail pipe.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor Last edited by 724x4a/cchevy; 11-03-2007 at 08:59 PM. |
.... Or you could just seriously fatten up the AF mixture by going with larger jets in the front and back. You arent going to make any friends with the EPA but Ive heard of people doing this to achieve what you want.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
#6 | |
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
You should get someone to take some pics and then post em.
Albie |
you got it !!!! yes i have it working great its kool i have manual choke and i set it were i can still rev it about 2500 and hit it and it will throw it about 6 to 8'
its bad ass ill get some pics tonight!!!!!!
Addicted to Chevy
mike, which kit did you buy? i have been wanting to do this for a ong while and i was wondering how much you paid and if it really does work. i have a holley carb with electric choke... btw
That sounds sooo cool! (Daydreaming...) I can picture it now melting the rubber window molding off that Fast n Furious junk at the stoplights
![]() Pictures, Pictures, We Want Pictures!!!!!!!!!!!!!!!!!!!!!!!!!!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Commander Taco Bello
i used to do this with my 77 step side, with full 3" dual exhaust.
nothing cooler than cruising under a bridge, turning off the key, coasting, then turning it back on with a BANG! |
had a home made kit on my 49 coupe pretty cool althought that lil 6 wouldt shoot 6foot flames. be prepaid to change your oil pretty often deppending on how much you do this. some of the unburnt gas will get down in the oil an wash the cylinder walls, and can mess up a perfectly good engine. good luck.
the kit is xtreme flame kits www.flamekitz.com it work great i just got home from going to dinner and tried a few different things i gotter now my truck is about 4 feet to bottom of the rocker to the ground and my pipes come out in front of the tire and it is 4 inch it will throw a 6 to 8 foot flame when i use the chock thats when it works the best it is time to cook some rice but some times it will back fire and make your ears ring with the windows up thats pretty loud hope i dont hurt the motor but ill watch that and change the oil when i get wild LOL...........
pics pics pics!
#15 |
yes. we want pics
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
#16 |
Some punctuation might help too.....that is very hard to read
#17 |
Did not know we were getting "graded" on this project!!!!!..........LOL!!!!!
#19 |
Saving 1 truck at a time!
Try this...always brings a smile to your face!
http://www.youtube.com/watch?v=Zk2ixe3xlQI and this... http://www.youtube.com/watch?v=1mwM7da0q0c
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 11-05-2007 at 04:20 PM. |
#20 |
now thats cool an old flat head at that every body should look at that !!!!!
#21 |
Addicted to Chevy
#22 |
Addicted to Chevy
ttt. anyone else have good luck with flame kits?
#23 |
I've got a kit on my 70 CST....works great. I can shoot a 2-3ft flame....great for tailgaters.....really.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#24 |
Addicted to Chevy
