Old 11-07-2007, 10:04 AM   #1
1984Silverado4x4
Need help hooking up gauge cluster with Tach
OK ive gotten it in this far and everything works except the tach which I need your guys help hooking up.
in the pictures theres two sets of wires. I dont know where either goes. would i be able to make connector for one set of wires to hook it up to the distributor?
Or do i have to buy one somewhere?
Which set of wires goes where?
Its no disgrace being poor. Its just inconvenient.
1984Silverado4x4 is offline   Reply With Quote
Old 11-07-2007, 07:26 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Talking Re: Need help hooking up gauge cluster with Tach
Can anyone help on this? I would like to know about this too.
tvblazer78 is offline   Reply With Quote
Old 11-07-2007, 07:49 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
White lead to the coil.
Black lead to ground.
Pink lead to ignition "ON" power source.
That other section of wires with the quick disconnect in the middle of it is anybody's guess.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-07-2007, 09:17 PM   #4
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
I wondered about that myself.
That cluster is gonna look good in there!
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 11-08-2007, 01:11 PM   #5
1984Silverado4x4
Maybe this picture will help with the other set of wires
Old 11-08-2007, 04:59 PM   #6
jdmaffeo
jdmaffeo's Avatar
My tach cluster didn't have those extra wires. It might be something that someone added on. Shift light? I dunno...
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop.
jdmaffeo is offline   Reply With Quote
Old 11-08-2007, 07:42 PM   #7
BLE 'BURBAN
Where did you get the cluster? And can you go back to the donor vehicle and trace the wires to their source?
Old 11-08-2007, 07:46 PM   #8
1984Silverado4x4
I found it at the junkyard lying on the floor of a truck that still had its cluster so those are all the wires I can get
Old 11-08-2007, 07:46 PM   #9
1984Silverado4x4
I assume those are all places on the distributor?
Old 11-08-2007, 08:06 PM   #10
BLE 'BURBAN
Only the white lead goes to the distributor.
The pink goes to your fuse block to a terminal that has power ONLY when the key is turned on. And the black lead just goes to a good ground.
Old 11-08-2007, 08:23 PM   #11
BLE 'BURBAN
Here's a thought..... Could this cluster have come out of a truck with a diesel? I've heard that those models with a tach picked up the tach signal from the alternator and perhaps those extra wires on the backside are for that purpose?
Old 11-08-2007, 08:43 PM   #12
1984Silverado4x4
So that means I might have to hook it up to the alternator too?
Old 11-08-2007, 10:32 PM   #13
77gmcjoe
77gmcjoe's Avatar
That really doesn't look like any kind of factory harness (the one with the red and yellow wires) to me. I'd say it's something that someone has added, although I really can't imagine what it would be. I believe you're right about diesels getting a tach signal from the alternator, but if it were a diesel cluster, I doubt it would have the harness plugged into the tach that included a coil lead. Also, a diesel would have a lower redline, I would think.
Just my opinion, but I'd ignore the oddball wires. Hook that baby up!
Old 11-09-2007, 01:34 PM   #14
1984Silverado4x4
How Do I hook it to the fuse block?
Old 11-09-2007, 04:33 PM   #15
BLE 'BURBAN
Go to your local NAPA auto parts store and ask someone knowledgeable there (manager assit manager, senior salesman for a G.M. FUSE BLOCK IGNITION "ON" TERMINAL LEAD. Part # to follow as soon as I can find my extra ones I have in my tool box.
Old 11-09-2007, 08:38 PM   #16
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Maybe a picture would help.
The top arrow points out a terminal lead that may be similar to BKE 'BURBA's description. Use this type of terminal to tie the pink wire to the ignition power bank on the fuse box. The second arrow shows the stock location for the pink wire (ignition power) for the tack.
BTW, The black wire can be tied into the 6-terminal Bus Bar Ground located under the dash. The white wire on the stock setup runs to a tach filter before tapping into the distributor. My guess is the tack filter is a RC circuit that filters out unwanted frequencies and voltage spikes. The tack filter may be needed to make the tach operate smoothly/correctly.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 11-09-2007, 08:47 PM   #17
BLE 'BURBAN
Ok here are the belden part numbers for the fuse block terminal connecters for G.M. vehicles 1977 and newer
BLACK = BATTERY POWER AT ALL TIME PART # 784800 & 784801
CLEAR = POWER ONLY WHILE KEY IS TURNED TO "ON" OR "ACC" PART # 784802 &784803.
Please note that one of each of these part numbers is of a "piggyback" design so you can plug in more than one lead to a given outlet on the fuse block and the other style is just a single lead plug in. Go look at them, detremine which will best suit your need, and put'r ta use dude!
Old 11-09-2007, 10:15 PM   #18
1984Silverado4x4
Originally Posted by boxrodz View Post
tack filter may be needed .
I assume you can get one of those from an auto parts store?
Old 11-09-2007, 10:58 PM   #19
BLE 'BURBAN
No tach filter needed. The white lead simply runs straight through the firewall and plugs into the tach lead terminal on the distributor cap.
Old 11-09-2007, 11:31 PM   #20
BLE 'BURBAN
Here's a pic of the terminal lead you want to get it is NAPA's part number 784803
Old 11-10-2007, 02:19 AM   #21
xtreme80
Wishin' I had more money!
xtreme80's Avatar
If you can't find a good ground either, that little bolt in the bottom left corner of the fuse box works well. That's where my tach is grounded. And BLE 'BURBAN is correct, there is no filter needed. The distributor has a slot next to the power wire for a tach hookup. You just connect the tach lead to that.
xtreme80 is offline   Reply With Quote
Old 11-10-2007, 03:04 PM   #22
1984Silverado4x4
WOOHOO!
It works!
I really appreciate all the great tips and help you guys gave me.
Now does anyone know how I can turn the odometer ahead so the mileage is the same as on my old gauge cluster?
Old 11-10-2007, 04:30 PM   #23
BLE 'BURBAN
WOOHOO!
It works!
Easy just unbolt the speedo head from the whole assembly and swap it out with your original speedo head unit.
Old 11-10-2007, 07:58 PM   #24
1984Silverado4x4
The original speedo wont fit in the new cluster.
Ive already tried that
Old 11-10-2007, 09:26 PM   #25
BLE 'BURBAN
In that case, disconnect the speedo cable at the transmission end and with a variable speed reversible drill, close the drill down on the INTERNAL cable in the speedo cable. Put the drill in reverse and squeeze the trigger.
Or let me get home and take some pics and I'll show you the fast way to do it.
