Bed wood help
I have a 72 GMC stepper and the PO had put aluminum sheets in the floor of the bed. Wood and strips are long gone. I am wanting to replace the floor, but I want to go a different route. Does anyone have the measurements of the original bed wood boards for a shortwheelbase? I need the widths, lengths, and height of the boards. I want to install that plastic decking boards in its place and still have the metal strips to where everything still looks like the old bed, just with boards that don't rot. I know the widths are different and I think they are all 1 inch in height. If anyone can help me I would really appreciate it. I will try and post pics when I start it if anyone is interested.
Lemme show you something!!
Re: Bed wood help
Check with GMC Pauls (link provided below)- he has a page that lays this all out. I'd double check before you use the composite deck material. In order for it to look like a stock wood bed- you're gonna need to rout a rabbet along the edges of each board for the steel strips to lay in. If the boards are solid composite then I think you'll be fine, but if they are hollow or honeycomb core-than routing the edge will compromise alot of their strength. Good luck and if you get it figured out- post some pics so we all can check it out!
http://www.gmcpauls.com/
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
Re: Bed wood help
I am using solid composite boards and plan on routing the edge if I can figure out how much to route. the boards are a kind of brown that goes well with my trucks paint scheme.
member #16
![]() Join Date: Dec 1999
Re: Bed wood help
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Re: Bed wood help
bump
Re: Bed wood help
I Picked Up All My Parts Thru Ebay
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
Re: Bed wood help
I`m not sure that syn-board will take the stress.It snaps when under stress.Not sure if it`s enough stress to matter.
Re: Bed wood help
them deck boards don't come in widths wide enough for the wider boards. you will end up redrilling your bed supports. personaly i would redo it with wood it lasted 35 years the first time around
common sense isn't so common anymore |
Re: Bed wood help
Right...no composite comes in 8" widths as far as I know as a deckbuilder. I have been told that glueing them up isn't an option either.
Stick with wood....the more exotic the better.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
Re: Bed wood help
The PO of my truck used a sheet of plywood, not great but why wreck a new floor if there is no where to park the truck or it is still a hauler with no time off for good behaviour. On the other hand if parking is under cover or you have a garage a wood floor IMHO still looks the best of all the different types of floors that I've seen.
Sorry that I cannot be of more help with your post then to give the above opinion, wish you luck with your bed project and look forward to progress pic's. esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 11-08-2007 at 11:15 AM. |
Semi-Senior Member
Re: Bed wood help
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
Fat Fendered Fleetside
Re: Bed wood help
I know that you can get that composite board 12" wide, but the 12" wide 'lumber' is only 5/8" thick. The 6" and 4" boards are all 1 1/4" or 1" thick.
you could just use 6" wide boards all the way across the bed, but you will need an extra strip or two and might need to realign them all for the bed to frame bolts.
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
