Oh,you can't buy that new
![]() Join Date: Apr 2000
73-80 frames vs. 81-87 frames, 1/2 ton ,2WD
anyone have pics of stripped down frames. I thought I remember their being different cross bracing and such on the 73-80 frames.?
I know the 81-87 front clip will fit a 73-80 frame with just minor cutting in the front, but what else is significant?? anything?? thanx ,crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: 73-80 frames vs. 81-87 frames, 1/2 ton ,2WD
when i had the 76 truck and i put the 81 cab on i found my 76 cab tabs were kinda rotted so i went and got an extra set of the cab mounts the steel ones that are riveted to the frame. The circumference of the hole is different sizes so you have to use the correct body mounts to the frame
i dont recall any other differences i used longbeds tho im not sure about short ones hope that helps ya
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
73-80 frames don't have the holes in the crossbraces for less weight, they are solid.
81-87 frames have the holes in them. I can get you a pic if you need it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Someone i know wants to re-do his 85 from the frame up and wanted a clean frame to start in advance since his sheetmetal is nearly perfect he just wanted to have a frame done then swap over all the metal.
This is a pic of a SWB frame i found very close to me and I had to assume it's a 73-80 frame. there was no frontend or cab metal to ID it. the 12 bolt was a bit of a giveaway to me that it was prolly pre-79. Oh yeah and now i see the frame in the front isn't cut like 81-up
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. Last edited by crossy; 11-08-2007 at 05:29 PM. |
Yep, 73-80.
I was going to mention the easiest way to tell, other than the crossmembers, was the bumper mounting on the frame horns. Round = 73-80 Triangle cut = 81-87.
