Old 11-03-2007, 07:37 PM   #1
Dusty4
A diesel in a 56?
OK, so this idea might be a bit out there, and not so hot rod, but my truck is going to work for a living, and put on about 17,000 miles a year, so great fuel economy would be a real plus. Anybody have any ideas of a diesel engine that might work out well? I only have experience with Mercedes, which are great, but a little spendy... thanks, Dusty
Dusty4 is offline   Reply With Quote
Old 11-03-2007, 08:24 PM   #2
DavesRide
DavesRide's Avatar
Re: A diesel in a 56?
If you got to do it go with the new Duramax Chevrolet. I will cost at least 10 grand, @ LEAST. A tuned Duramax has been known to see 12's at the strip. High dollar project my friend. Do it and post for the rest of us. I have test driven many 07 and 08 Duramax trucks and they ain't nothing like the old Bangers. If you are gonna tow then get the noisy Cummins. Both are very expensive and are gonna cost in maintanence. The injectors for the D-MAX which are always getting changed are a few thousand by themself. They go bad without warranty and you get to buy some more let alone the tech want to charge to diag and repair. Gas for me Bro.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 11-04-2007, 07:46 PM   #3
mylow53
mylow53's Avatar
i've dreamed of my dodge diesel "cummins" in my 53. but i talked to a guy that does the "ford cummins" dodge engine in a ford... and he said the ford swap is pretty simple since the cummins is an inline 6 cyl. but the weight would be enormus.. i did some mesurements and the cummins 5.9 will fit in a stock engine compartment. or at least real close. you may need an inch or so since the engine is a tad longer than the 235. i don't know how much these weigh by themselves but my dodge 4x4 2500 weighs 8,000lbs (4 tons) empty. you may have stearing problems. thats if you could get your suspension off the rubber bump stops...
if you do the swap i want to see pictures.....
GT
http://www.fordcummins.com/
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 11-04-2007, 08:09 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
You might want to keep an eye on this thread. He's putting a diesel in his 52 'burb.
http://67-72chevytrucks.com/vboard/s...d.php?t=249457
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-06-2007, 10:22 AM   #5
chevyrestoguy
chevyrestoguy's Avatar
A DuraMax in an older truck would be freakin' awesome. Expensive, but awesome. The cost of a totalled late model truck would be high. I figure that buying a total would be the only way to do it. That way you can use everything diesel related that's on the truck. If you had to piece it together, that would be very costly.
chevyrestoguy is offline   Reply With Quote
Old 11-06-2007, 10:32 AM   #6
Jebb1978
Jebb1978's Avatar
If you take this advice, and it sounds like good advice. I would try to adapt your truck to the frame of the totaled out truck. That would also solve your weight issues....
Just a thought.
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 11-07-2007, 01:00 PM   #7
robin58
If you don't necessarily want the latest and greatest in diesels, you'll often run across listings on eBay for the 6.2L variety. Mostly they have been pulled out of HumVees when they were upgraded to 6.5L motors. They usually run around $250.
robin58 is offline   Reply With Quote
Old 11-09-2007, 08:45 AM   #8
gumps10
gumps10's Avatar
4bt My friend.....
Not as heavy as a 6bt Can make decent power and more reliable than a 6.2/6.5
Go to 4btswaps.com...
Lots of info there
gumps10 is offline   Reply With Quote
