Old 11-07-2007, 10:24 PM   #1
cstm68
cstm68's Avatar
saginaw 4 speed
i need pics of shifter linkage for a saginaw 4 speed.
what kind should i use?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 11-08-2007, 12:42 AM   #2
cstm68
cstm68's Avatar
Re: saginaw 4 speed
anyone ???
will a factory camaro shifter work
Old 11-08-2007, 07:38 AM   #3
Re: saginaw 4 speed
Not real sure.But the side loader Muncies put the shifter into the seat and require a shifter to locate the lever forward.There is prolly a shifter made for the application.There is one for Muncies,farly new part.Before those,there`s a 55-57 bench seat application that guys would use.I`m sure there`s one of those for Saginaws.My friensd has one in his project that is a rolling frame at the moment.I`ll see what he`s come up with.
Old 11-08-2007, 03:08 PM   #4
airdale94
airdale94's Avatar
Re: saginaw 4 speed
It would work but you may have to fab. a reverse linkage. Reverse is on the tail in a a Borg Warner and on the cover in a Saginaw. I'm not sure what trans. they put in a plain jane Camaro but I dought it was the Super T-10. If it's not a Z-28 it might bolt right up.
airdale94 is offline   Reply With Quote
Old 11-09-2007, 08:28 PM   #5
bucky_21_7
bucky_21_7's Avatar
Re: saginaw 4 speed
Depends wat saginaw it is there 2. One out of like monzas camaros late 70's and then they made one for 81,82 camaros corect me if i'm worng. I ended up ordering the oen for the camaro whitch was wrong. Use hursts websight and go to there tranny i d charts that shoudl tell you wat tranny you have.
bucky_21_7 is offline   Reply With Quote
Old 11-09-2007, 08:59 PM   #6
airdale94
airdale94's Avatar
Re: saginaw 4 speed
That's right they did put some 4-speeds in the 3rd Gen Camaros. I think they were B/Ws though. But when looking at Hurst's
app guide I think they had the reverse on the cover like the Saginaws.
