Old 11-09-2007, 09:37 PM   #1
green724x4
green724x4's Avatar
Unhappy sand Bag'n
Ever since I installed my 4 inch suspension lift I have had a sag in my rear leaf springs. My truck was stored for 10 years with a heavy chain in the box. We rearched the springs before installing. I have been running 305x70R16 and I like the look of the smaller wheel well with that size of tire. I still kick myself for not going with 35"s. I was wondering if I could drop the front end to match the rear.
I am going to swap my sbc for a blown bbc 427. I would think that the bbc should drop the front end a little. Although there is like 6 leafs in the front and only 3 in the back.
Hear are my measurements to the top of the wheeel well.
FD 43.75
FP 43.75
RD 41.5
RP 42
green724x4 is offline   Reply With Quote
Old 11-09-2007, 09:49 PM   #2
JAKES 68GMC
Aluminum slot wheels rule...
Re: sand Bag'n
looks good to me, I like the front end up a little stance actually.
JAKES 68GMC is offline   Reply With Quote
Old 11-09-2007, 09:52 PM   #3
rcflyer1234
rcflyer1234's Avatar
Re: sand Bag'n
You could install an add a leaf in the rear to raise the rear of the truck just a little bit.
rcflyer1234 is offline   Reply With Quote
Old 11-09-2007, 10:02 PM   #4
1969k10stepside
Re: sand Bag'n
Maybe even a small block in the back.I'd raise the back a little before lowering the front down..You payed to raise it so why lower it down? This way you can fit a bigger tire on if you upgrade in the future..
1969k10stepside is offline   Reply With Quote
Old 11-09-2007, 10:41 PM   #5
cobinder
Everything is work in progress
cobinder's Avatar
Re: sand Bag'n
If you like the ride get an ORD zero rate. It wil lift your rear 1", and not change your ride, or shocks or brake lines etc.
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 11-10-2007, 02:15 AM   #6
earl87gta
earl87gta's Avatar
Re: sand Bag'n
I would raize the back up to match the front.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-10-2007, 07:22 AM   #7
duallyjams
duallyjams's Avatar
Re: sand Bag'n
My vote goes to ORD zero rate.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-10-2007, 07:47 AM   #8
earl87gta
earl87gta's Avatar
Re: sand Bag'n
DIY zero rates are cheaper.
Earl
Old 11-10-2007, 05:18 PM   #9
vtblazer
vtblazer's Avatar
Re: sand Bag'n
Never heard anyone say that before...
vtblazer is offline   Reply With Quote
Old 11-10-2007, 06:06 PM   #10
Zoomad75
K5Camper
Zoomad75's Avatar
Re: sand Bag'n
I wouldn't touch the front springs if you are dropping a big block in there. That should drop the front down by an inch at least.
I certainly wouldn't drop it before adding the engine because it will drop more with the wieght of the big block on it. Then you will be putting spring back in to lift it up again.
Leave it be for now!
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 11-10-2007, 08:01 PM   #11
green724x4
green724x4's Avatar
Re: sand Bag'n
Ya, I thought a big block would drop it down a little.
The whole problem with the 1"spacer is I already have a 4" block in the back. I could do add a leaf but I am just going wait for the big block swap..
Old 11-11-2007, 07:45 AM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: sand Bag'n
I have tried rearched springs and dont like them. I put a set on and within a year they were sagging and not sitting level. The spring shop said old springs don't hold up well and relax differently. By old i mean 30 years old.
So I put a new set of springs on and everything id good.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
