05-15-2002, 09:58 PM | #1 |
? 4 700r4 guys
what brackets are necessary for the tv cable adj. and mounting for cable and carb attachment.
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
05-15-2002, 10:01 PM | #2 |
all you have to locate is the stock bracket from the origional motor, which is a self adjuster. no carb rod is necessary (at least not on mine)
------------------ 1967 C-10 Longbed rollpanned front&back Cowl induction hood '91 5.7 liter/vortec heads, 700r4 trans. holley headers, holley fuelpump, holley mufflers. converted to edelbrock performer/carter 625 hei/advanced recurve MSD 6A ignition box. Accel supercoil Accel custom 8.8 wires 5 bucks a plug even! faster!!!!!!!!!!!!! soon to be lowered "a little" looking for a good tonneau cover. |
05-15-2002, 10:27 PM | #3 |
its all about the +6 inches
Advisable to get it adjusted by a pro. THey will use pressure guages to set it 100% correct. The TV cable does mor than just kick down to passing gear, it controlls clutch packs and fluid pressure too.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. E-mail longhornmail@yahoo.com My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough? Columbus Ohio |
05-16-2002, 06:46 AM | #4 |
Use a 350 turbo bracket with a universal TV Cable. I bought all of the fancy stuff from Bowtieoverdrives and my transmission man laughed and told me to send it back.
------------------ 71 C20 Cheyenne 71 K10 SWB Cheyenne 72 C10 Cheyenne
68 50th Longhorn Custom Camper 396 A/C 25 options 71 C20 Cheyenne 71 K10 SWB Cheyenne 72 C10 Cheyenne ----------------------- Slaughter, La |
05-16-2002, 12:40 PM | #5 |
Boosted Member
Mine is a Holley piece for use with a Holley carb. It was like $16 from Jegs or Summit. Night and day difference between this and the cobbled together bracket I had before. HIGHLY RECOMMENDED!!
[img]http://www.freephoto-i.net/users/ls6speed/700R4%20Bracket.JPG[img/] ------------------ -Jeff ------------------------- "You might be a REDNECK if someone yells 'Hoedown' and your girlfriend hits the floor" -Jeff Foxworthy '69 C-10 LWB (hot rod) '67 C-10 SWB (hot rod in progress) '92 K1500 'Burban (daily driver/tow vehicle)
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
05-16-2002, 12:42 PM | #6 |
Boosted Member
oops...
05-16-2002, 03:32 PM | #7 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Digital camera's...aint they great!
Pictures worth a thousand words ------------------ "71"blazer,rust free(bought in Arizona),350SBC (375HP),700R4,factory G.M. TPI.Living in Santa Barbara,California.Ongoing project.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
05-16-2002, 07:41 PM | #8 |
67 LS1 SWB - got a part # for that gizmo? I'm currently running a 700 to a Holley carb and you can only imagine my setup. That part in the pic looks like a life saver. Noticed your throttle cable is rubbing on your intake though. Small price to pay I suppose as long as it makes that 700 run right.
------------------ 72 C-10 Custom Deluxe LWB, 2WD, 350 700r4, Holley 600 UNITED STATES ARMY - ALASKA "Rangers lead the way!, Medics bring them back!" |
05-16-2002, 07:44 PM | #9 |
nevermind about the part#..I found it.
