alternator up grade
Guys I know there has been a lot of discussion on this issue, I did a search and found a few but got kind of confussed, I want to get rid of my external regulator and upgrade my chargeing system, I would like to have a complete parts list of what I need, I want to go with at least 100 amp alternator.
and some step by step instructions, I am very very week when it come to automotive wireing, would like to see picture also, Thanks, Sam
72 LWB chevy truck. Pasadena, Texas |
About half way down the page I listed a step by step and a TERRIBLE drawing. But it should help you do the job.
Initially I installed mine the same way Longhornmail did his but I kept noticing problems with voltage when my electric cooling fans came on, low voltage. I've since revised the wiring to the schemic I drew and everything is fine. The key is the large output wire directly to the battery or J-block. http://67-72chevytrucks.com/vboard/s...ght=ALternator |
Half a bubble off!
Sam, I agree there is a lot of confusing info on this topic. I got a kit at the local O'Reilly's that had the necessary wires, etc, and installation instructions for less than $10.00. Made for a very simple, easy, and quick changeover. If I would have messed around with some of the things I've seen posted, I'd still be scratching my head and trying to figure it out. With the kit and the new regulator, the changeover was done in 15 minutes. The kit doesn't really consist of much, but I considered it to be worth the price because of the time savings and the knowledge that it was done right. If you can't find it, let me know and I'll get the part # for you.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
ttt
newly minted old timer
why are you guys all changing over? is there something wrong with the old style?
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
mtdave,
On my truck when I come to a stop at night the lights dime a lot and there is a small flicketring going on with them, at idle, once up graded you can go with an internal, regulator, and bigger, alternator, should stop all of this, some guy I have read on here is so bad that the ingnition stumbles a little due to the problem. Sam
its all about the +6 inches
More amps is always a good thing. I know my headlights are brighter since I swapped over.
Plus, it is one less thing to go bad. The externial ones always seem to be rusting and taking a crap. I chainged the one in my old lognhorn 3 times in less than 2 years of driving. |
#8 | |
Bloo
i probably did it different from everyone else on here... i left my old (good) external one plugged in, cut the wires, and spliced in the new plug, then bolted on the alt and plugged it in... 18 volts almost all the time (short in the fuse block, the motor shakes it around sometimes)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
I was looking at the drawing that piston posted, it shows the white wire going to the brown wire comming out the old regulator, I want to completely remove my old regulater, so once I get it out the way, what do I need to do, puty the while with the brown, that was going into the regulator????????
Sam
The brown wire (going into the cab) goes to the white wire (going to the alternator)
![]() Join Date: Dec 2002
More info....!978 Chevrolet Light Duty Truck Service Manaul shows 'Generator Output Test "....#2 (F) connects directly to Battery +....#1 (Relay) connects to a " 10 ohm; 6 watts or better" resistor and then to Battery +..... 'Bat' terminal on alternator connects to one lug of ammeter ; other ammeter lug to Battery +. For test purposes a volmenter is also connected across the battery terminals............
My setup connects Alternator #1 (Relay) directly to Battery +.....Hmmmmm?..... And, the alternator goes bad abput every year.. ( replaced for free per "lifetime warranty" ! ) ... Will install the above mentioned resistor ; hope it will prevent alternator burn-out.............. Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
i bought a powermaster 100amp alternator from scoggin dickey for like 80 or 90 bucks plus shipping
68 short step, 406/700r4, 9" w/discs. |
