01-05-2003, 08:21 PM | #1 |
700r4 back up lights???
When you converting to a 700r4 for a stick how do you go about hooking up the backup lights? It there a reverse netural safety switch that has to be hooked up too?
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
01-05-2003, 10:52 PM | #2 |
It's already on your column, looking at your signature.
'69 Chev Cust/10 swb, 350/700R4, 5"/6" '70 Chev C10 swb, 67 front, 454/700r4, 4"/5" '73 Chev stepper, 350/3 spd '84 Chev K20 350/4 spd '91 GMC 1500 Suburban 4x4, 350/700R4 |
01-05-2003, 10:55 PM | #3 |
Sorry, 350 is probably your engine, not trans, I don't have to work tomorrow and have a buzz. Anyway, if you have auto column, it's on there.
01-05-2003, 11:06 PM | #4 |
So Many Ideas, So Little Money
if your goin from a stick how do you plan to set up with a shifer? factory on column? or a B&M or somethign on the floor,floor mount B&Ms have the swithes all you gtta do iswire them..
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
01-05-2003, 11:15 PM | #5 |
its all about the +6 inches
A toggle switch will get you through an inspection in a pinch.
01-05-2003, 11:43 PM | #6 |
Column shifter, Lokar linkage.
The truck will most likly never go throught any type of inspection here in cali. I just want some reverse lights. Since im in the process of getting everything back together from putting the 700r4 in, I figured I might as well do it all. The column does or did have another connector on it. Its now sitting on my desk. Is that what I need to connect? And to what?
01-06-2003, 02:35 PM | #7 |
i have a 700r4 but i dont have backup lights
68 short step, 406/700r4, 9" w/discs. |
