Old 11-12-2007, 10:07 PM   #1
tkeduk8r
tkeduk8r's Avatar
if you havnt changed you rear end gear oil since the 70's you may have this...
Just doing new brakes, heater core, tranny flush and filter and rear lube as I do with any new vehicle I get... so I cracked the differentil conver on the Dana, and I get this... WOW!!!! thought I only read about this kind of thing....
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 11-12-2007, 10:11 PM   #2
corn
Re: if you havnt changed you rear end gear oil since the 70's you may have this...
Ewwww. Looks like it needs some pepto...
corn is offline   Reply With Quote
Old 11-12-2007, 10:14 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
like I ALWAYS say when ppl ask about gears.... drain the oil. It is even more neglected than brake fluid.
Old 11-12-2007, 10:14 PM   #4
1969k10stepside
Yuck!That's why I always change the fluid in the differentials when I get one if I plan to drive it any,and also why I tell people when they want to know their gear ratio to pull the cover and get the numbers from the ring gear,and replace the oil!
1969k10stepside is offline   Reply With Quote
Old 11-12-2007, 10:20 PM   #5
SacramentoJoe
Always Fixing Things
SacramentoJoe's Avatar
Just make sure to add some more sawdust in there when you add the new gear-oil. That way, it will still purrrr..
I had some chocolate milk in mine one time...I decided I would not back down into the lake anymore to unload the Jetski. None the less, a couple month later, new carrier bearings.
Just an Average Joe
‘68 GMC 307 3spd – My dad's original truck
310,000 miles
SacramentoJoe is offline   Reply With Quote
Old 11-12-2007, 10:44 PM   #6
chev74
Addicted to Chevy
chev74's Avatar
Sawdust... thats an old rear end remedy. makes em quite
chev74 is offline   Reply With Quote
Old 11-12-2007, 10:50 PM   #7
bowtieboy93
bowtieboy93's Avatar
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 11-12-2007, 10:51 PM   #8
72BLUZ
72BLUZ's Avatar
Just Flush It All Out With Brake Cleaner. And Then Fill It Up With Lucas Oil. And Hope For The Best
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 11-12-2007, 10:55 PM   #9
Longhorn Man
I wouldn't bother with lucas... most of there products are snake oil anyways. I WOULD clean it up real good, I would consider pullin the axles too... but once I knew all the water and crap was gone... I'd go with a synthetic oil.
Old 11-12-2007, 11:00 PM   #10
Did it run out of there or roll like a terd?
Old 11-12-2007, 11:02 PM   #11
dan42
dan42's Avatar
I am swapping motors this weekend in my '67 and drained the oil in the SM465, and at least a quart of water came out the bottom. It hadn't been driven with the water (I think it was stored somewhere where the roof leaked) so it was not mixed with the oil, but some nasty chunks came out. We took the top off and blew it out pretty good with brake cleaner - hopefully it's good to go.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-12-2007, 11:09 PM   #12
72BLUZ
72BLUZ's Avatar
Synthetic Oil Is Great Stuff, But You Will Find Using Synthetic In Old Gears Will Cause The Gears To Heat Up Quicker. Thats A Fact I Learned Working On And Around Gears In The Shop Where I Work.
Old 11-12-2007, 11:25 PM   #13
Longhorn Man
to a point yes... but not overheat.
Old 11-13-2007, 09:17 AM   #14
BHRS
BHRS's Avatar
Do the best you can to get the junk out, fill it with good gear oil, run it for 100 miles and drop it again. When you drop it the second time make sure the fluid is at operating temp so it will flow better and the contaminates will be suspended in the oil. Refill will good gear oil and keep your fingers crossed...
Good Luck!!!
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 11-13-2007, 10:38 AM   #15
72BLUZ
72BLUZ's Avatar
Exclamation Re: if you havnt changed you rear end gear oil since the 70's you may have this...
Let Me Explain It This Way, With All New Gears It Is A Wise Idea To Run Syn. But With Gears With Age And Miles On Them, The Strength In The Metal Has Weakened Over Time. So The Thicker The Oil The Less Heat It Builds. Lucas Works Well In Keeping The Gears Lubed And Keeping Down Heat For More Life
Old 11-13-2007, 11:51 AM   #16
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Pictures like that make me cringe when I hear my dad say things like "unless its leaking, don't touch it".
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 11-13-2007, 11:58 AM   #17
68gmsee
Active Member
68gmsee's Avatar
More like some Keopectate for the runs...
I just did mine on my 68 GMC and it still looked good. However, it only has 28K miles on it...
68gmsee is offline   Reply With Quote
