Old 11-12-2007, 05:51 PM   #1
David Johnson
David Johnson's Avatar
Long or short water pump?
Does a 70 blazer/truck with a 350 have a long or short water pump. Does anyone have a picture of a stock set up?
David Johnson is offline   Reply With Quote
Old 11-12-2007, 06:16 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Long or short water pump?
Stock was short pump.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-12-2007, 07:19 PM   #3
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: Long or short water pump?
short water pump was used from 1955 to 1967 along with the canister type oil filter and small journal size crankshaft's , in 1968 they went to a spin on oil filter long waterpump and big journal crank , so the correct answer for a 1970 350 is it came from the factory with the long waterpump ,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 11-12-2007, 07:41 PM   #4
cdowns
cdowns's Avatar
they used short pumps till after 72
Old 11-12-2007, 07:43 PM   #5
john
member #16
john's Avatar
That was for cars only not trucks. Trucks short through 1972.
john is offline   Reply With Quote
Old 11-12-2007, 07:47 PM   #6
Tx Firefighter
Yep, trucks are a different animal than cars. 73 was the changover year for us truck guys.
Old 11-12-2007, 08:53 PM   #7
19673ontree
CAN'T FIX NOTHIN
Talking Re: Long or short water pump?
I sure did not know that !! wow that is strange , a short waterpump on a chevy v8 after 68 cool !!!!!!!!!!!!
underdash AC
Old 11-12-2007, 09:01 PM   #8
67_C-30
I have a radical idea!
67_C-30's Avatar
GM was always a little behind on trucks because back then more of a commercial use vehicle than they are now. Cutting edge technology was less of a concern for most trucks buyers, and GM took measures to keep the reputation of their trucks as being very reliable. It's the same reason that while '67 model cars got 350's as option, they waited until '68 to put them in trucks. The short water pump set-up was tried and true and they probably wanted to field test them in cars first.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-12-2007, 10:32 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
trucks didn't get 350s till 69 actually.
The vette used the short pump for quite a few years after the trucks stopped using them.
Old 11-12-2007, 10:59 PM   #10
72armyswbtruck
72armyswbtruck's Avatar
Right on the money about that one, I love my dealer option brochures
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
