Old 11-12-2007, 08:44 PM   #1
bg67lwb
78 C-10 how to shorten steering column??
I searched the forum looking for a definitive answer, didn't find one. Have any of you guys shortened the steering column on your truck? I've got the seat all the way back and still have to bend my elbows past 90 degrees to hold the wheel. If I could move the wheel closer to the dash by 3-4 inches, it sure would make it a lot more comfortable. There was a mention of a telescoping Cadillac column but no year model was given for the donor or the truck it was going in. Another post for a '84 said he used a '86 Caprice column. Nothing specific to my '78. Help!!
bg67lwb is offline   Reply With Quote
Old 11-12-2007, 11:15 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 78 C-10 how to shorten steering column??
Do you have a tilt? That made a HUGE difference in the comfort on my truck.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-12-2007, 11:28 PM   #3
bg67lwb
It is a tilt column and even has a smaller aftermarket wheel but it needs to be closer to the dash.
Old 11-13-2007, 11:18 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i know how you feel im 6' like 270 lbs and it seems tight for me too i have no clue but eagerly wait for an definitive answer myself
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-13-2007, 01:02 PM   #5
streetstar
streetstar's Avatar
There is a write up on the 67-72 boards about collapsing the steering column a couple of inches -- but i dont know if it will work on a later model.
You would have to find the thread to get all the details - but basically , you unbolt the colum, take the center section out under the hood and collapse it - move it forward in the cab and re-attach. This was a safety feature years ago - if you got into a hard enough impact , the column would collapse and absorb some of the energy -- so pre-collapsing would negate that feature - so dont drive into any brick walls if it works
streetstar is offline   Reply With Quote
Old 11-13-2007, 01:36 PM   #6
canadianc-10
ive never checked to verify it , but ive heard the columns from full size vans are shorter then trucks
canadianc-10 is offline   Reply With Quote
Old 11-13-2007, 02:10 PM   #7
knightlife
Dark Heart Motorsports
knightlife's Avatar
next time I go out to LKQ I will measure some for yall that are close to the same kind of build (i.e. chevy vans, trucks, cars), and tell you what their lengths are... Its on my to-do list now, so when I go out there next monday I will return with results
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 11-13-2007, 02:26 PM   #8
bg67lwb
Thanks, I read the write-up in the 67-72 boards. It is very informative but not specific to my '78 C-10. It's a different beast and I'm hoping someone else has shortened their column or found a shorter replacement that's close to a drop-in.
Old 11-13-2007, 08:06 PM   #9
b1v3r
I have an 85 ck and I have the same problem. They built the seat too close to the dash for me>. 6 ft and 300+ lbs. But im not giving up my truck!!
b1v3r is offline   Reply With Quote
Old 01-28-2008, 09:57 AM   #10
Bainbridge
Is there any update on this? I'm wedged in right now.
Bainbridge is offline   Reply With Quote
Old 01-28-2008, 02:32 PM   #11
Kaysenmc
Kaysenmc's Avatar
Most 77, 78, and 79 Olds 98's (caddy's and big buicks prolly did too) had a tilt and telescoping columns. I have owned two and both had them. I currently have one that is still in the car if interested. It has the key and cruise switch. Let me know
87 black silverado swb, tbi 350, 700r4, 3.40 gears. 2.5 drop spindles , 2 inches off stock coils, flip kit out back. cragers with radial ta's... ongoing piddle project!
1970 Olds rallye 350, street strip 403/350 3.73 posi. Looks stock/runnin 12's!
86 K5- SOLD!
Kaysenmc is offline   Reply With Quote
Old 01-29-2008, 01:26 AM   #12
bg67lwb
I'm interested. Are you fairly certain that the column will work? Bolt in or much modification necessary? I was considering moving the mounting bracket about 2 inches up the tilt column that I have.
Old 01-29-2008, 02:12 AM   #13
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Have you thought about changing out the seats? My '90 burban had the factory bench seat in it with factory whel and no tilt. Steering wheel was in my belly all the time as well even with the seat all the way back(I'm 5'10" & 320#) put in a Grant wheel w/quick disconnect, still in my belly but not as bad. then I found a set of custom bucket seats with center console/jump seat, got them installed and now I have about a 3 inch gap between wheel and belly. Little more head room too and the seat isn't even back all the way either
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-05-2008, 01:19 AM   #14
LMDGUY
LMDGUY's Avatar
what about aftermarket columns? has anybody used them? My 73 dosnt have tilt and Im hating it.
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 02-26-2015, 05:10 PM   #15
Gregski
Gregski's Avatar
man I don't like abandoned threads especially when they were spot on for what I was interested in doing, so resurecting rather than starting a new one
Gregski is offline   Reply With Quote
Old 02-26-2015, 06:41 PM   #16
esbstuff
Me to. I will be following...
esbstuff is offline   Reply With Quote
Old 03-02-2015, 03:29 AM   #17
2wd73blazer
I'm interested in the answer too. I'm working on a crew cab so I may just move the seats back if I can't find the answer.
2wd73blazer is offline   Reply With Quote
Old 01-23-2020, 05:43 AM   #18
moneyeater
moneyeater's Avatar
Hello from Germany,
i´m interested in this too and even though this thread is very old i´m curious if someone found a solution.
I found that squarebody syndicate sells a new column that is shortened 2" towards the dash.
Now i need one that is shortened in the enginebay to fit a new shaft for a rack and pinion steering setup!
Are there any measurements i can work with?
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 01-23-2020, 07:20 AM   #19
cadillac_al
I wonder if the Camaro columns are any shorter. I have just been suffering through it for 40+ years.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-23-2020, 06:36 PM   #20
Big Chip
Big Chip's Avatar
There's always this but it is pricey. I have no experience with it, just came across it a while back.
https://squarebodysyndicate.com/inde...egory=11122134
Big Chip is offline   Reply With Quote
Old 01-24-2020, 07:49 AM   #21
jkk
jkk's Avatar
I have this one in chrome very nice column well built and looks killer
jkk is offline   Reply With Quote
Old 01-24-2020, 12:01 PM   #22
Ziegelsteinfaust
I did this to my old C20.
When you drive the shaft in 2.5 inches. You have to modify a few things.
First measure the column mount bolt centers. This is how much you can easily shorten. If you want custom the welder will be involved.
The amount you shorten you need to move your park neutral safety switch on the front of the column up to match. You will need to cut slots into the outer column, and the inner column to match.
Then get a piece of exhaust pipe to cover the old hole or water can get in. I welded mine on, but you dont really have too.
My column worked fine the way I did it, but my friend had to trim some plastic to work it. Also the PRND21 slider may not work. Mine didnt work before so no change there.
Then reassemble the unit.
Ziegelsteinfaust is offline   Reply With Quote
