Newbie: I Need Transmission Help
Re: Newbie: I Need Transmission Help
Saginaws are pretty much junk unless you baby them. Any beating at all and most break. I would rebuild your trans and live with no 1st gear syncos. Easy and cheaper
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
What do you consider babying? Ive got the 3 with the syncros and mines great, shifts real nice, and i learned on it, so ive been grindin the gears for a while, and its still really nice...for 40 yrs old...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
i had a '66 years ago, was my first vehicle, and it had a 3 speed saginaw. i dogged the mess out of it, clutch and trans were both good when i traded it.
![]() Join Date: Oct 2007
The 66 and later all-synchro Saginaws are beefier than the earlier units. You will have to get shift rods from a 66-up truck if you swap to the later transmission, or modify your original shift rods.
I'm currently working on a similar swap. My original 64 tranny is toast, and pops out of 3rd just like yours. I found a heavy duty Muncie 3-speed from a 71 Chevelle with 402 big block. I picked up some shift rods from a 69 C10, and I'm getting my clutch and pressure plate rounded up this week. I hope to tackle the swap over the Thanksgiving holiday. I don't think the driveshaft needs to be shortened, but it's not a big deal if it does. |
are you hauling anything in your truck? if not the way gas is consider a t-5 your trans is junk now along with the clutch. you could hit the pick-a-part and get a t-5 and even maybe a good used clutch for under $200 bucks. might even find one on craigslist.
I grenaded 2 3 speeds in 2 years....I then decided to go with a muncie 21 4 speed and added a hurst shifter on the floor (was column shifter). 8 years later, the M-21 is shifting strong.
1963 LWB 350 M-21 4spd comp/edelbrock/holly/LT1 1.94/1.60 ![]() |
i wanted to keep as close to original as possible, but i plan on keeping the truck for as long as i can. with that said, i am considering a 4 speed on the floor swap. what cars or trucks can i get that out of?
