Old 11-13-2007, 02:32 PM   #1
STL_66 Chevy
STL_66 Chevy's Avatar
Someone HELP im locked out!
so today i was replacing my rockers and put the doors on to check the fit.... everything lined up so i decided to put the door latches on just to make sure the latch didnt move the door out of wack.... needless to say now my passanger door wont open... the latch wont open when i push the button on the door handle.... so i tried to pull it from the inside.... no luck... ive tried evereything and dont know what to do.... can someone please help!!!! there must be a way to get the door open! good news is that the driverside door opens and closes better than new.
by the way the latch that is stuck is a new replacement latch purchase by PO.
1966 Chevy C-10 Fleetside
Check out http://jcox.tumblr.com/ for progress updates!
STL_66 Chevy is offline   Reply With Quote
Old 11-13-2007, 02:53 PM   #2
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Re: Someone HELP im locked out!
For a quick fix, just to get your door back, unbolt the hinges from the cab, and open it suicide style. You will have your door, and then you can figure out whats going on.
Imperial Kustom is offline   Reply With Quote
Old 11-13-2007, 03:32 PM   #3
STL_66 Chevy
i tried to do that and the latch wont release to free the door. even with the hinges unbolted the door is still stuck in the latched position. !
Old 11-13-2007, 04:05 PM   #4
kris's66lwb
resident wrencher
try kicking it from the inside but dont do it from the out side it makes a big dent
kris's66lwb is offline   Reply With Quote
Old 11-14-2007, 07:30 AM   #5
64GMCHorsepower
Justified!
Have you tried taking the door panel off and moving the mechanism from inside the door....I have done that before...just pull the rod inside the door...........
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 11-14-2007, 09:47 AM   #6
STL_66 Chevy
i have the door panels off and i have tried pulling the mechanism from the inside but no luck.... i might have to do it like the dukes of hazard and go through the window!
Old 11-14-2007, 02:03 PM   #7
55dude
55dude's Avatar
if you have the drivers door panel off take 10 minutes to watch and study the movements of the lock mechanism and compare the passenger lock movements. couple of key things is patience and light, don't force it. in the end you will have learned something: how the door latch operates! good luck.
55dude is offline   Reply With Quote
Old 11-16-2007, 06:48 PM   #8
64GMCHorsepower
Justified!
you ever get this open?
Chad
Old 11-16-2007, 07:06 PM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
something may have slipped look at it and use a screwqdriver to pry up while you push the button ive had this happen on newer trucks also look with a little light to see if there is a jammed broken off piece of the lock mechanism.. in all likelyhood it will need to be replaced... also inspect the whole piece around the door and make sure nothing is holding the door shut around the edges
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-18-2007, 07:54 PM   #10
STL_66 Chevy
i finally got a chance to work on the door tonight... and i got it open.
i ended up loosening the bolts that hold the strike plate from the inside of the cab... not an easy task! i got the bolts loose enough that the door just popped opened. i looked at the assembly and the strike plate and couldnt see anything wrong with it.. i guess if you didnt have the those unwanted demons your not doing it right!
thanks everyone for your input and advise
Old 11-19-2007, 05:41 AM   #11
55dude
55dude's Avatar
check the wear pattern on all of the pieces that will tell you whats up. you blame it on gremlins and it will do it again. here is a trick i learned: clean up the latch and striker with layout blueing and check where the dye has been rubbed off and adjust as needed.
Old 02-10-2008, 04:49 AM   #12
Orange
Licensed to Thrill!
Orange's Avatar
IIOY?
DLB
(Found this thread searching and I couldn't resist).
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
