Old 11-17-2007, 10:44 PM   #1
jorgensensc
jorgensensc's Avatar
What size bolts?
Hey all,
Quick question, What size bolts hold the front bed panel on a short step. I also need the size of the bolts that hold the fenders on. I have a bed Bolt kit that I've had since my last stepside, but it doesn't have these bolts in it and rather than order them I thought I would run down to the Hardware store and pick up what I need. Mainly I just need the pitch/thread count and the length.
Thanks in advance!!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-18-2007, 05:54 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: What size bolts?
Fenders are 5/16x 1 inch.
I'd surely order them though. The fender bolts have a philips screw head. Mar-K sells the whole kit for both sides with nuts for 26 bucks. There's no way you'll be able to buy all the bolts and nuts for 26 at the hardware store.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
