Old 11-18-2007, 10:28 PM   #1
7071Bluck
Frame
I am wondering if a 2wd suburban frame and a 2wd longbed frame are the same any help would be greatly appreciated
7071Bluck is offline   Reply With Quote
Old 11-18-2007, 10:59 PM   #2
806em55
806em55's Avatar
Re: Frame
I was getting on here to ask the exact same question. I have a 71 burb that has been wrecked bad enough not to want to clip it. Not to many resorces locally for a new one though plenty of long beds!!!!
806em55 is offline   Reply With Quote
Old 11-18-2007, 11:51 PM   #3
earl87gta
earl87gta's Avatar
Re: Frame
there the same just use your burb body mounts for the rear of the burb only ones that are the same are the front cab mounts so you will need to use the old burb body mounts or make some.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-18-2007, 11:58 PM   #4
sbrban
Re: Frame
I just happen to know where an extra frame is layin around
you never have too many suburbans....
sbrban is offline   Reply With Quote
Old 11-19-2007, 12:10 AM   #5
earl87gta
earl87gta's Avatar
Re: Frame
Me too but its way to far away for those guys.
Earl
Old 11-19-2007, 12:57 PM   #6
806em55
806em55's Avatar
Re: Frame
I wish i was closer and i would scoop them up. For now i will have to take the advice and modify a long bed. Thanks for the help!!!!!
Old 11-19-2007, 04:59 PM   #7
earl87gta
earl87gta's Avatar
Re: Frame
Any time thats what were here for if your going to lay it in the weeds I would try to find a 4x4 they curve up more in the front so if you convert it to 2wd it will give you 2in or so of lower stance.
Earl
Old 11-20-2007, 11:41 AM   #8
OldCreek
OldCreek's Avatar
Re: Frame
The very rear of the frame rails dip down a little more I believe in the burb. Also, they stick out the back, past the body, and the bumper bolts to them.
There was a post in this section about it several months ago. In fact, I think it was Frizzle who posted about it.... I think.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-26-2007, 12:42 PM   #9
70 Suburban
Rods
Re: Frame
hey Im about to do the tahoe job on my Sub so if someone wants my frame b-4 I cut it up let me know. I would rather it keep a sub on the road then to chop it up.. I will need your body to frame mounts cause I will be using a swb truck frame. Im in texas pm me
70 Suburban is offline   Reply With Quote
Old 11-27-2007, 11:37 AM   #10
Frizzle Fry
Frizzle Fry's Avatar
Re: Frame
If you build a tahoe you won't need the #4 position body mounts from the Burb frame. You can just use cut-down bushings on top of the rails as I did.
Frizzle Fry is offline   Reply With Quote
Old 11-27-2007, 01:06 PM   #11
70 Suburban
Rods
Re: Frame
ty ill start on this in Jan.
