Old 11-19-2007, 05:41 AM   #1
55dude
55dude's Avatar
Re: Someone HELP im locked out!
Originally Posted by STL_66 Chevy View Post
i finally got a chance to work on the door tonight... and i got it open.
i ended up loosening the bolts that hold the strike plate from the inside of the cab... not an easy task! i got the bolts loose enough that the door just popped opened. i looked at the assembly and the strike plate and couldnt see anything wrong with it.. i guess if you didnt have the those unwanted demons your not doing it right!
thanks everyone for your input and advise
check the wear pattern on all of the pieces that will tell you whats up. you blame it on gremlins and it will do it again. here is a trick i learned: clean up the latch and striker with layout blueing and check where the dye has been rubbed off and adjust as needed.
55dude is offline   Reply With Quote
Old 02-10-2008, 04:49 AM   #2
Orange
Licensed to Thrill!
Orange's Avatar
IIOY?
DLB
(Found this thread searching and I couldn't resist).
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
