Old 11-20-2007, 07:08 AM   #1
jott_06
Camaro Club
jott_06's Avatar
SBC to BBC. Who's done it, Whats needed
My truck currently has a 350 in it and a th400 tranny. A guy i know that parts vehicles out just tore down a 76 chevy pickup with a 454 and he said he's pricing everything to sell so i wanna buy the 454 to put in my 68. What all is needed to do this swap. I know as far as the tranny it will bolt right up but what do i need for motor mounts or will the stock small block mounts work. I've delt with alot of small blocks but i've never dropped a big block in any thing so this is new to me as far as what will bolt up and what won't. Thanks
jott_06 is offline   Reply With Quote
Old 11-20-2007, 07:35 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: SBC to BBC. Who's done it, Whats needed
You need the big block towers that bolt to the frame, bigblock radiator, bigblock fan shroud, You might need to upgrade your fuel line to 3/8. Is the motor stock? You might need to install heavier springs in the front. Make sure you get all the brackets and pulleys. I'm sure I left some things out but someone else will jump in and help you.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-20-2007, 10:27 AM   #3
ChevyDude
I am in the "collecting parts" stage for this swap. My truck came with a 307 and 4 speed. 454 block was purchased, BBC towers, BBC Power Steering remote unit and brackets are needed, BBC Alternator Brackets brackets, and all the correct pulleys. I decided to get all the original stuff that allows for a Short water pump. I went with billet polished 3 groove crank pulley for AC and also a 2 groove pulley for the short water pump, and the 1 groove Power Steering pulley.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 11-20-2007, 01:13 PM   #4
My72BB
If you are running a stock fuel pump you need to put a return line on your fuel system back to tank. Also, as far as cooling goes...a fan clutch for a 454 like say 77 and up from a 1 Ton will be the thicker heavier duty one that will really make a difference if you have Air Conditioning. NAPA or the dealer are the places I have had luck getting that style...Autozone and Orielly, etc do say theres are heavy duty but are the thin style and not worth a crap.
You also might want to look at your front springs...The Big Block is just a "scosh" heavier than the 307.
Alan
My72BB is offline   Reply With Quote
