Old 11-20-2007, 11:23 PM   #1
OrrieG
OrrieG's Avatar
Re: 60's mustang tank into 59???
I've seen some truck where they have removed the rear cross member between the spring perches. I don't want to do that, I'm concerned about the frame speading, compressing or getting out of square in that area under off-road torque loads (my truck is a 4wd). I'd still like to see how the tank fits.
Old 11-22-2007, 02:28 PM   #2
72Blazer San Jose CA
http://members.cox.net/ncc1701m1/monty's56truck/
You can buy them from mustang part supplier cougar tank the same
1969 1970 20 gallon and 22 gallon
72Blazer San Jose CA is offline   Reply With Quote
Old 11-22-2007, 03:18 PM   #3
Bob@ProAuto
You may want to measure up some of the following tanks. You may have to trim the lips on the frame to get these in and custom build mounts for the straps.
77-82 GM van tank (Hollander #1052). 31" (not including the flange lips) x 22" x 12.375" . 1.25" filler on the driver's side rear.
1983-95 Van tanks (Hollander#1295 & 1585) are the same except for 1.625" filler.
1987-95 van (Hollander # 1418 & 1583) shows the same except for no filler specs.
If your using a fuel injection system, these have you typical GM big "twist lock" senders.
Bob@ProAuto is offline   Reply With Quote
Old 11-22-2007, 07:37 PM   #4
solidaxel
solidaxel's Avatar
While we are on this subject, is there a rear fill (center fill) that I can access under the license plate in the roll pan, Muatang, Monte Carlo ,Buick Regal 70's, vintage.
Does anybody have a pic of this operation?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
