New Clutch
I am in the process of replacing my clutch in my 72 4x4. I would like to upgrade the flywheel and clutch while I am in there but am worried about how much stiffer will the clutch pedal feel with a Centerline or McLoud clutch in.
Also how difficult would it be to change over to a hydraulic clutch and what would I need to do it? Thanks, Eric
72 Chevy LWB 4x4 |
Fabricate till you "puke"
If i ever do a stick again, I will go centerforce on the clutch. IMO the diaphragm clutchs have a better "feel" than a 3 finger. Centerforce sets the spring pressure up pretty conservative on the street stuff, & the rely on the weights on the fingers for extra clamping force. your best bet no doubt would be to talk with tech dept @ centerforce , to get the proper setup for you intended useage. I cant help much on the hyd clutch.......good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
