Old 11-21-2007, 11:28 PM   #1
wugunguy
70 C/10-Work in progress
wugunguy's Avatar
FS: 3 speed w/Dana 20
Came with my blazer, was told it ran but really doubt it.
$50, can be picked up around Omaha, NE or in Northeast Kansas
In the garage
1999 Dodge Dakota Sport-Daily Driver
1972 Chevy K/5 CST AC/PS/PB/4x4/Tow Hooks/Tilt
1970 Chevy C/10-Current project
wugunguy is offline   Reply With Quote
Old 11-22-2007, 12:18 PM   #2
69TowRig
Re: FS: 3 speed w/Dana 20
If you are willing to part out the t-case shifter box, I am looking for one that is not worn out. The detent plate above the bottom cover on mine is rusted out badly and the shafts inside mine are in bad shape as well.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 11-22-2007, 01:23 PM   #3
wugunguy
wugunguy's Avatar
69towrig, do you have a picture of exactly what you need so I can compare?
In the garage
Old 11-22-2007, 05:03 PM   #4
69TowRig
I'll buy the whole shifter box off of it. The bottom end of the shifter (inside the box) is completely worn out on mine as well. Basically everything that bolts onto the side of the transmission housing, less the links that go to the T-case is what I am looking for. I had a thread about the detent plate a while back, no one had responded to it. I will dig up the pictures from that for the plate, but I basically need another good box since about 4 or 5 major parts are worn out on mine.
