Old 11-21-2007, 11:43 PM   #1
cstm68
cstm68's Avatar
relocating ignition?
i would like to relocate my ignition switch so that when the keys are in it they dont hang down and scratch my paint.
anyone done this, have pictres or an idea for where i could relocate it too?
i do have a full center console from the dash to the back of the cab between my buket seats. (see pics in my build thread) i was thinken there or on the botton edge of the dash
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 11-22-2007, 11:09 AM   #2
clos69
Its Topless Season!!!!
clos69's Avatar
Re: relocating ignition?
Try this http://www.brotherstrucks.com/prodin...number=BR10035
clos69 is offline   Reply With Quote
Old 11-22-2007, 11:13 AM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Take the ignition key off of the ring. Then the rest of the keys won't be hanging down. That seems a whole lot easier that relocating.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 11-22-2007, 11:38 AM   #4
berencam
berencam's Avatar
how about relocating it to the instrument panel?......
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 11-22-2007, 11:53 AM   #5
cruiserman
Put a piece of tape on the dash under the key .
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 11-22-2007, 02:50 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Build urself the little piece of metal and then glue it under the key set..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-22-2007, 05:01 PM   #7
jorgensensc
jorgensensc's Avatar
How about this:
Brothers Link:
Hope this Helps!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-22-2007, 06:38 PM   #8
68gmsee
Active Member
68gmsee's Avatar
What I did on mine...
Made a duplicate. Placed it in my key chain. Used the other single key for the ignition switch. Keep my other keys in my pocket.
The reason for the duplicate is in case I forget and leave the key in the ignition. Which I've done more often than I'd care to admit.
68gmsee is offline   Reply With Quote
Old 11-22-2007, 06:57 PM   #9
BurnoutNova
BurnoutNova's Avatar
why do you need a duplicate if you leave it in the ignition???... just open up the door and get your key out.
BurnoutNova is offline   Reply With Quote
Old 11-22-2007, 07:10 PM   #10
68gmsee
Active Member
68gmsee's Avatar
I guess I should have mentioned. I have 3 trucks and a suv. By "mine" I meant all of them. I use a single key on all the vehicles and keep spares in my key chain. I have up to 10+ keys on my key chain/ring and it will also wear down your ignition switch with all the weight...
