Question on model #
I am looking at a truck to buy and have the model & Vin # he give me over phone and I looked at the decoder but this just doesn't add up could it be short a digit or what? Model # CE10934. It supposed to be a 71 cheyenne short box? Any info???
![]() Join Date: Dec 2006
Re: Question on model #
That mdl # is a long fleet.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
its all about the +6 inches
I've seen plenty of model numbers missing digits... yours is missing a couple... but yes, that does decode as a 1/2 ton long wheel base with a fleet side bed.
Thanks, I'm wondering if the cab was replaced or glove box changed or if truck has been shortened. Any way to tell by vin # or something since I can't see the truck up close?
My bet would be shortened either by frame swap or cut. It is amazing how many Cheyenne trucks have shrunk in the last 35 years....
#8 | |
Supposed to look at truck Saturday, can anyone give me values of shortened LWB to SWB fleet cheyenne, if all in working order and good shape body wise? Any advice appreciated
If they converted it over well, using good parts did not coble the brake system together or if cut the weds are safe and properly done, not much different from factory 2wd, especially if originality des not matter. If they are trying to pass as original truck I would question somethings. As far as what it is worth- that depends on you, do you just want a truck to enjoy or what? Need to see some pictures of truck and of SPID.
#10 | |
#11 | |||
Union Electrician
Nice looking truck and has a great looking bed on it.
The interior is wrong for a Cheyenne, should be woodgrain trim on the gauge bezel, glovebox door and ash tray. It also should have the woodgrain trim on the outside lower moldings, and a tailgate band with the woodgrain as well. Looks like the make this truck into a cheyenne from a stripdown longbed with A/C, or cab swapped from an A/C truck., just my .02...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#12 | |
#13 | |
![]() ![]() Join Date: Jul 2003
![]() Quote:
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
