Turn Signal Switch
I am swapping out the turn signal switch in my tilt column and I need to know how to do it. It doesn't look like it goes in without taking the column apart.
Brad
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Turn Signal Switch
If you are talking about the plastic plate the stalk screws into, it's really easy. Took me five minutes after studying it for a minute. I think there were three screws and a clip.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
So is it pretty much put in in there and wiggle it around to get it to lock in place or is it more involved? I can just see me breaking the hazard switch now
Not really. It is a bit fussy to get in, but I didn't break mine and I am the world's best 'breaker' when it comes to stuff like this.
How did you do it? Did you have to turn it or twist it? How far does it sit in?
The master of disaster
all i had to do to get to mine is pull the wheel and pull the three screws and then pull on it and then reverse the process. thats the way it was with my 79 and my 82 so hope this helps and gl to ya
1994 Chevy Project in the works Life is like a jar of japalino's what you do today will burn youre a$$ tomorrow! |
When I took out the original one it was removed the screws and pretty much pry it out. I can get the new one in but it wont go in as far as the original one did. Cant figure out what I am doing wrong.
the wires always try to bunch up behind the switch... you may have to pull them from the outside of the collumn while putting the switch in...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
Yep...the right side was a tricky one at first, then I put a little force behind the pressing and it slipped in with a click.
So did you angle in the hazard knob first then move the left side in while pulling the wire harness?
Actually I installed it the other way around....left side in first, then the right.
When I tried to install it I angled it to the right trying not to knock off the hazard switch (which didn't work). So after I broke the hazard switch I tried installing it as is for practice and this sucker will not go in. I checked the old one vs the new one and they are identical in size. I am thinking it has to be the wiring harness somehow but I cant where it is hanging up at. I will keep at it and one way or another I will figure this out.
Mine snapped right in after a bit of work on the right side....sorry to hear you are having a hard time with it.
