Old 11-25-2007, 11:15 PM   #1
Grizzlybear
Grizzlybear's Avatar
65 Power steering
I just bolted up my power steering gear box on my frame today and was wondering how you all bolted up your pitman arm (not sure if thats what you would call it or not) on your passengers side. There is one hole on the frame that you can put the bottom pitman arm hole/bolt through and makes everything look like it's lined up pretty close and level but I don't beleive it's perfect. Just curious how everyone else has done it and if i need to put a level on the steering linkage and just drill 2 new holes in the passenger side frame? hope this makes since to ya'll if not i can take some pictures of what i'm talking about. Thanks,
Jesse
Grizzlybear is offline   Reply With Quote
Old 11-25-2007, 11:35 PM   #2
Grizzlybear
Re: 65 Power steering
Here are some pictures with it bolted in the hole i was talking about. Not sure if it will workin that hole or if i needs to be moved towards the back of the frame more so the steering cross shaft is more level? Thanks,
Jesse
Old 11-26-2007, 09:30 AM   #3
04Xrider
Registered thread killer
04Xrider's Avatar
I have a completely different setup on my 1966. It is in the two hole in front of the one you have yours in, and goes straight down into the arm.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
