11-25-2007, 09:36 AM | #1 |
Neat comp cam selection program
I found this nice program from competition cams for selecting a cam , gives estimated horsepower and torque, a bit like desktop dyno.
Dunno how accurate it is maybe someone can compare it with desktop and let us know, here's the link www.competitioncams.com |
11-25-2007, 10:09 AM | #2 |
Re: Neat comp cam selection program
got a more specific link???
11-25-2007, 10:50 AM | #3 |
I checked it out, you need to download the program (comp cams software) 20MB, after you install it you need to enter all your engine specs( heads, flow, valves, basic cam selection, intake & flow) pretty neat if you have that information.
11-25-2007, 12:18 PM | #4 |
I built mine up, and the curves/numbers it produced looked almost exact to what Desktop Dyno did over on Billa's thread in the engine section.
11-25-2007, 05:46 PM | #5 |
Need a bigger hammer..
Cool, saving that one for my 454 build.
1968 GMC 3/4 LWB fleetside Custom Camper 2018 Silverado High Country 2500HD Duramax 4X4 |
11-25-2007, 07:43 PM | #6 |
67-72 Addict!
Cool, I downloaded and played with it a bit. I'm assuming it's roughly 20% or so above real life numbers. It's amazing what a good set of heads and a little bump in c/r will do for a motor!. I need heads,lol.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-26-2007, 12:56 AM | #7 |
11-26-2007, 12:46 PM | #8 |
Between Trucks...
That's a cool little app, thanks for the link...
Beat it to fit, Paint it to match... |
11-26-2007, 02:12 PM | #9 |
i monkeyed with it last night. for some reason it will not let me tailor the bore and stroke from stock. anyone else have this issue?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
11-26-2007, 02:20 PM | #10 |
Between Trucks...
Try clicking on 383 stroker...
11-26-2007, 02:35 PM | #11 |
i have a stoked mkIV block though. i select 454 and it wont allow me to change the bore and stroke. am i missing something somewhere??
11-26-2007, 02:41 PM | #12 |
Between Trucks...
I just stroked a 454 to 571. Click to the right of the bore or stroke and type in your numbers and hit return...
11-26-2007, 03:46 PM | #13 |
ok...got it!
11-27-2007, 12:21 PM | #14 |
has anybody figured out the head selection on this program? i'm unsure what my Eddy 454-O semi-open chambers would be considered on the drop down menu.
