Old 12-03-2007, 10:40 AM   #1
fast69
fast69's Avatar
spring hight
Ok here is my problem. I am wanting to put drop springs on my truck . 2 1/2 in the front but not shure what to use in the rear. My problem is my truck sits level right now but I am not shure if my rear springs are saging or what the problem is. I was told the truck has 3/4 ton springs on the rear but I am not positive if that is tru. Any help or advice would be great. Thanks for all your help.
"Its better to be alive and cool than dead and uncool" 1969 chevy c10 lwb,350-400 turbo and 260 air.
fast69 is offline   Reply With Quote
Old 12-03-2007, 02:45 PM   #2
Mondo
Mondo's Avatar
Re: spring hight
I can't imagine your truck is different than the rest, probably does have something to do with your current springs.
Lots of places have what you want:
http://www.earlyclassic.com/catalog.aspx
Mondo is offline   Reply With Quote
Old 12-03-2007, 03:05 PM   #3
see ten
WTB this ad
see ten's Avatar
Re: spring hight
How far is it from the axle tube to the frame now? ECE claims a 6" spring will leave 3" between the axle tube and frame. If that's correct we can assume a factory height spring would have 9" of clearance. Take a current measurement to figure about how much the truck has sagged and then adjust accordingly for how much lower you want to see it.
see ten is offline   Reply With Quote
Old 12-03-2007, 08:05 PM   #4
fast69
fast69's Avatar
Re: spring hight
Thanks for the input. My truck sits pretty high to begin with so I am wondering if the front springs were changed also. Thanks again for the help.
