Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-22-2007, 08:09 PM   #501
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
You're wlecome Gringo
No pics but a little more progress. I replaced all the rear wheel studs with longer ones. Ended up going with NAPA 641-3112. They require the holes to be drilled out just a little bit to 9/16" because of a slightly larger knurl.
I also painted my calipers and drums with black POR-15 and put the rear 5/16" spacers on. When I convert to rear discs I'll go to a 1/4" spacer because the rotors are about 1/16" thicker than the drums at the hub/studs.
Won't be doing much on this over the T-Day weekend, but my next project will be the tubs which includes the 68 front clip If we have a sunny day over the next few days I might find time to take some shots for the the Nov TOTM contest
Frizzle Fry is offline   Reply With Quote
Old 11-24-2007, 05:27 AM   #502
Tyner
Tyner's Avatar
Hey Friz, do you still have the 20 inches you cut out? My wife is talking about having another kid and that means my Blazer needs to be bigger.
Seriously though, good job on the Tahoe/Suburban(Taburban?), I've enjoyed this thread along with other stuff you have in the FAQ. Keep up the good work, can't wait to see this thing driving around.
'72' Blazer 4x4-Daily
'55' International P/U-My Project
'06' Buell XB9SX-Commuter
'01' Yamaha Raptor 660-Sand toy
Somehow they all ended up blue.
Tyner is offline   Reply With Quote
Old 11-26-2007, 02:23 PM   #503
Frizzle Fry
Yes I do, let's do it
If you're in Hillsboro it's only a matter of time before you see it because it's my daily driver I commute on evergreen between the airport (Jones Farm area) and Ronler Intel.
Old 12-05-2007, 10:30 AM   #504
ciburb
I like the work that you've done. Looks good. I was wondering where you got your roof rack.
ciburb is offline   Reply With Quote
Old 12-06-2007, 01:56 PM   #505
Frizzle Fry
Roof rack was a dealer install that I have shortened 10" You see them on ebay every now and then. They also came on the same era Blazers and even non-GM cars/trucks.
Old 12-06-2007, 03:14 PM   #506
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
WOW Mike!!!! She is looking awesome!!! I really should check the board more often, I have missed a bunch. I'm kinda stalled on mine at the moment. Taking some time to get my PD certifications back. That, and it's snowmobiling season!!!!!!
It's looking fantastic!!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 12-07-2007, 10:34 AM   #507
Hart_Rod
Hart_Rod's Avatar
Here's a picture of one I picked up off of the board.
Frizzle, can you send me some measurements for where your rear brackets are screwed on? I liked the placement of yours better than mine, so I welded my original holes up, .
R
Hart_Rod is offline   Reply With Quote
Old 12-09-2007, 01:21 AM   #508
Frizzle Fry
R
Good choice They look better further aft. In fact, I've moved mine back a bit more when I shortened it. I'll get you the measurements.
Old 12-09-2007, 01:23 AM   #509
Frizzle Fry
Just a little preview...
Old 12-09-2007, 01:49 PM   #510
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Noice!!!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 12-09-2007, 11:24 PM   #511
Frizzle Fry
More...
I got the other one off. These things are not as easy to remove as you might expect. I chose to leave the lower/outer extremities of the tubs at the fender lip instead of wrestling with all those spot welds. This way I can just mate the new inners up to the remaining OG sections.
Here's what I'm talking about:
Cut at upper radius of tub:
And cut down closer to fender arch with lower section remaining:
This shows how much the OG inners arch inward and narrow at the top. I'll gain over 2" of usable space for tire width at extreme drop (not to mention more drop ):
Here's the DS removed and aired out with bags on internal bump-stops. You can see the line marked on/near the "4th door" where I will clearance back 1":
Old 12-09-2007, 11:28 PM   #512
Frizzle Fry
...more
Old 12-10-2007, 02:50 AM   #513
gringoloco
A guy with a truck
gringoloco's Avatar
Looks familiar- I like it! Keep 'em comin'...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-12-2007, 03:54 PM   #514
71'tahoe
71'tahoe's Avatar
Whats up frizzle,
Glad to see you are still going strong.I am still on the hunt for another sub to restart my project.You are an inspiration to alot of us on the board.Keep up the good fab work.I bet alot of guys check out this thread before they kiss there wifes when they get home after work!!!
71'tahoe is offline   Reply With Quote
Old 12-12-2007, 07:41 PM   #515
texanidiot25
Eat My Rust
texanidiot25's Avatar
Been watching this, man, you amaze me. It looks so clean!
But, I guess your sacrificing some groceries for the tubs and axle?
texanidiot25 is offline   Reply With Quote
Old 12-13-2007, 08:51 AM   #516
68SSC10
68SSC10's Avatar
Are You Interested In Selling The Wheels That You Took Off??
I've Reached The Age Where Happy Hour Is A Nap!!
68SSC10 is offline   Reply With Quote
Old 12-13-2007, 08:58 AM   #517
1Ton
1Ton's Avatar
That there is awesome work. I have gone through the whole thread. I will keep this one in the subscribed section.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 12-13-2007, 02:42 PM   #518
Frizzle Fry
Thanks guys! You really help keep the motivation going. I'll be doing more with the tubs tomorrow.
Old 12-13-2007, 02:50 PM   #519
hotrodhomi
hotrodhomi's Avatar
Mike, Do you have a problem putting gas in that thing? It looks like the gas fill tube runs uphill. Does this cause a hydro lock situation?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 12-14-2007, 07:55 AM   #520
Frizzle Fry
No problems. The gas cap is well above the tank.
Old 12-14-2007, 09:55 AM   #521
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
awsome
LOW DOUGH is offline   Reply With Quote
Old 12-14-2007, 02:45 PM   #522
BACKYARD88
BACKYARD88's Avatar
looking good Frizzle! I LOVE the way it's turning out!
-Mike Owen-
Old 12-17-2007, 04:53 PM   #523
Frizzle Fry
Well, before installing the tubs I had planned to clean up the notch and POR-15 it. in the process I found that my sway bar brackets were starting to bend a little at the tips. So I decided to pull them out and run another 2x2 across the notch (actually through both notches) protruding beyond the notches to act as the sway bar end-link brackets as well as stiffen the whole notch/bridge assembly. I'm also relocating the end-link "brackets" (now 2x2) slightly so there won't be as much stress put on the end-links.
I know I know pics... well it's not installed yet, just the old brackets removed and the notch prepped for paint. That involved removing all the hose clamps for the various air lines, etc, zip-tie'ing the lines away from the frame, and wire-wheeling away.
While I'm in there I also decided it would be a good time to relocate my upper shock mounts inward to allow me to run a shock that won't limit my rear suspension travel.
I ended up going with a shock spec'ed out for a 1984 F150 rear (old vs new):
Old 12-17-2007, 04:57 PM   #524
Frizzle Fry
I mentioned before that I replaced all the rear wheel studs with longer ones. Ended up going with NAPA 641-3112. They require the holes to be drilled out just a little bit to 9/16" because of a slightly larger knurl.
Here's a shot of the old vs new:
Old 12-17-2007, 05:03 PM   #525
Frizzle Fry
...and I've been collecting and prep'ing my Glock/Camaro rear discs:
Masked the friction surfaces:
Painted with High-Temp Ceramic paint:
Glock's Brackets POR-15'd:
Calipers:
and front rotors to match the rear (still need to clearance the hubs a little for the Coys to fit, then I'll paint then like the rears:
