Old 11-30-2007, 06:29 PM   #1
nicktheknife
Exhaust leak?
When my engine is running, there is a kind of popping/clicking sound that gets more rapid as the rpm's go up, exhaust leak? Valves out of adjustment?
nicktheknife is offline   Reply With Quote
Old 11-30-2007, 08:31 PM   #2
corn
Re: Exhaust leak?
Could be either one. Do you have an automotive stethoscope?
http://www2.northerntool.com/product-1/385487.htm
corn is offline   Reply With Quote
Old 12-01-2007, 10:21 AM   #3
nicktheknife
Re: Exhaust leak?
Nah, but I could get one, what would I be looking for when I get it?
Old 12-01-2007, 10:27 AM   #4
Slammed70
Slammed70's Avatar
Re: Exhaust leak?
Lifters will create a metallic clicking noise. Header leak will be a uniform popping noise that always sounds trhe same.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-01-2007, 11:34 AM   #5
60ratrod
yes, i do
60ratrod's Avatar
Re: Exhaust leak?
for exhaust leaks, i would use a piece of vac hose and listen around your manifolds. a stethoscope can be picked up at your local parts store real cheaply. valves when driving would sound more like a click and slight knocks where exhaust sounds like popping sounds. you also may be able to feel hot air. i would check your exhaust doughnuts
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 12-01-2007, 01:49 PM   #6
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Re: Exhaust leak?
Chunk of hose works every time and you probably have a 5/8 chunk about 3 ft long collecting dust. If not buy a chunk as you will get two uses from it as you will need some for a PCV valve, pwr. brake vac. hose line etc. one day. Header leaks sound like a steady ticking sound different then valves. If your not sure go by a garage [ma & pa type] as any mechanic can tell you if it's a header leak or valve train noise that you are hearing.
If it's a header leak I use Permatec Ultre Copper .... cheaper then gaskets and works great.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 12-01-2007, 03:18 PM   #7
nicktheknife
Re: Exhaust leak?
thanks alot guys
Old 12-01-2007, 03:47 PM   #8
OrangeCrush1970
OrangeCrush1970's Avatar
Re: Exhaust leak?
Check your manifolds. I just went thru a set of crummy gaskets on my headers and had the same sound. If I can give my $.02, spend a few extra bucks on good gaskets...you'll be happier in the long run.
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 12-01-2007, 05:04 PM   #9
Ole Blue 68
Ole Blue 68's Avatar
Re: Exhaust leak?
Depending on the material, you can also double up on the gaskets as well. But I would agree with OrangeCrush, go with good gaskets and fasteners.
Ole Blue 68 is offline   Reply With Quote
Old 12-05-2007, 11:28 AM   #10
chris71
chris71's Avatar
Re: Exhaust leak?
ive got an exhaust leak in my chevelle right now, its killing me, a leak will increase with rpms, but will go away or decrease when your foot is off the pedal. look for the notorious black soot around your header/manifold gaskets or collectors/donuts. the PO used the cheap paper gaskets and they always blow sooner or later, i want to step up to the copper gaskets with the locking fasteners soon, saves headaches like these down the road. good luck
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
