Old 12-06-2007, 03:46 PM   #1
bigo181979
Junior Member
bigo181979's Avatar
lq4 Motor, 4L65E Tranny, Computer, and Harness $3250 obo NEW LOWER PRICE
I have 6 LQ4 6.0L complete take outs (motor, tranny, harness, t-case and computer) from H2 hummers available for sale, this price is for one unit with all accessories, harness and ECU these are 4wd set ups and come with the transfer case, but they can be converted over to 2wd very easily.
All have less than 50k miles on them. They were removed so we could put duramax motors and allison trannys in to the hummers.
I am located in wichita, ks and would prefer locall pickup but I will ship if needed. You can PM me here or email me at: bigo181979 at yahoo dot com.
Thanks and I hope this can help someone!
Here is some photos of one of the motors I, they all look the same as this one. Let me know if you would like some more pics!
bigo181979 is offline   Reply With Quote
Old 12-06-2007, 09:58 PM   #2
68 short step
Re: lq4 Motor, 4L65E Tranny, Computer, and Harness $3250 obo NEW LOWER PRICE
when you convert it from 4wd to 2wd, i beleive you have to change the outputshaft of the trans(this involes tearing the trans all the way down) and get a 2wd tailhousing....is that correct??
68 short step is offline   Reply With Quote
Old 12-06-2007, 11:50 PM   #3
jrdv
jrdv's Avatar
Just curious--what does it cost to convert an H2?
john
jrdv is offline   Reply With Quote
Old 12-07-2007, 08:51 AM   #4
bigo181979
Junior Member
bigo181979's Avatar
Tail housing and output shaft both have to be changed, my local transmission supply shop quoted me aboout$175 for both and as far as I know the tail house is just bolted on and you can just pull the old output shaft off and slide the other on, no tearing into internals of the trans.
john
A turn key conversion on an H2 runs $29k that gives you 6.6lbz motor, allison trans and the tap up tap down transmission feature, also you get a selectable 2hi 4hi 4lo transfercase and all your factory options work as thay did from the factory. We use only original genuine gm parts for the conversions, so it looks like gm made iyour hummer with a duramax.
Thanks,
Orlando
Old 12-14-2007, 05:31 PM   #5
bigo181979
Junior Member
bigo181979's Avatar
ttt
Old 01-11-2008, 04:18 AM   #6
bigo181979
Junior Member
bigo181979's Avatar
I have 4 left
Old 01-11-2008, 09:09 AM   #7
cstanley
cstanley's Avatar
can the transfer case be made to function with electronic switches? I guess that's how they work originally? I am thinking about this for my '72 blazer, so I guess i'd need a ford dana 44 front axle with the pumpkin and the driver's side?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 01-12-2008, 04:44 AM   #8
bigo181979
Junior Member
bigo181979's Avatar
Hummers have an electronic selector on the dash that is how it functions and yeah you would need the pumpkin on the drivers side.
Old 01-21-2008, 07:29 AM   #9
bigo181979
Junior Member
bigo181979's Avatar
Weekely bump....
