Pulling a travel trailer
I've got a travel trailer that weighs around 5500-6000 lbs. The other day I pulled it to a hunting lease in another state about 275 miles away. I had heard that I shouldn't pull in overdrive so I was pulling it in Drive. The road was hilly, but not all that bad. I noticed the truck getting pretty hot, especially on the hills. Seems like it was up around 210, sometimes higher, but it never did get in the Red. The engine RPM's were up there pretty high in Drive and I figured that might have something to do with it running so warm so I dropped it into Overdrive and the temp. went back down to just above normal. It normally runs right around 180 degrees. This truck was not originally set up for towing, but since I only pull the trailer about two or three times a year, I didn't think it would hurt it. My question is what can I do to keep the temp in the normal range and what can I do to the truck to make it a little more capable of pulling a load. I've already put a tranny cooler on it. I'm not sure what gears I have in the rearend, but I would suspect they're pretty high. Any comments appreciated.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Addicted to Chevy
Re: Pulling a travel trailer
did you get the biggest tranny cooler they had?
can you get #s from your rear end so you can find out exactly what you have back there? |
210 ECT?? or tranny temp? 210 is fine for ECT.....thats not hot at all. You better pull it in drive.. or you will be replacing that transmission.. Its going to run a little hotter because your working it harder.. its fine... Just don't pull it in overdrive.....ever lol
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
Robert Olson Transport
![]() Join Date: Oct 2002
as long as you arent in the red youre fine the trans cooler is a good idea
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
I'll climb under the truck tomorrow and see if I can find a tag on the rear end anywhere.
#6 | |
BTW spudz, I just came through your neck of the woods the other day. I was coming from Charleston on 78 on my way back to GA.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado Last edited by crawdad; 12-06-2007 at 08:35 PM. |
#7 | |
BTW you might want to make sure your clutch fan is ok... Maybe consider an electric fan??? It shouldn't run hot with a little more RPM...
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. Last edited by spudz; 12-06-2007 at 10:08 PM. |
#8 | |
Consider the same engine in an 88 Camaro does not switch on the fan till 230F, you are fine. Water Wetter seems to help. if you had a Trans Temp gauge, I bet it would have up when you shifted to OD.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
#10 | |
#11 | |
Oh,you can't buy that new
![]() Join Date: Apr 2000
no tag, there is a three letter code stamped in the right side tube usually dead on top, but sometimes more on front of tube. Like KTA, TUB, TGA etc. use a file and flashlight.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
