Old 12-08-2007, 09:04 PM   #1
LIVE RUST
1966 Chevy/GMC Mongrel K10
LIVE RUST's Avatar
Re: 4WD Won't engage, '96 K1500 Suburban
Are you sure the fronts are spinning in low?
LIVE RUST is offline   Reply With Quote
Old 12-08-2007, 09:31 PM   #2
'72 Chevy Suburban
Chevy's Rock!
'72 Chevy Suburban's Avatar
I am pretty sure. I felt a clunk and heard the extra whine that is usually associated with the fronts turning and I didn't take it above 30MPH because of the whining. It had the same feel as 4LO. The only thing that I don't remember was whether or not the light stayed on in 4LO. I googled it at lunchtime and came up with a pretty interesting link. I am going to check this stuff out this weekend: http://autorepair.about.com/library/a/1/bl378.htm
Do you think that this system and troubleshooting would apply to my truck? It sounds like a similar setup and it goes back to your earlier comment about a leaking vacuum hose.
Thanks,
John
'59 NAPCO Pickup
'70 K10 Pickup 350
'72 C20 Suburban 350 (MIA)
'57 Chieftain 455
'68 Firebird Convertible - 400
'68 Catalina Convertible - 400
'85 Vette
'72 Chevy Suburban is offline   Reply With Quote
Old 12-08-2007, 11:10 PM   #3
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
These electric shift junkers have 4 main components and 10 miles of wiring to go wrong.
1) Control head (button assembly)
2) Tranfercase control module (TCCM) - under the dash
3) Encoder motor - located on the tranfercase
4) Front axle disconnect – located on the front axle
If you actually hear and feel a clunk and the tranfercase will actually go into low range but you have no front wheel action, then you have a problem with the front axle disconnect. Unlike the link you posted regarding the S-10 Blazer, the full size rigs did not use vacuum to engage the front axle. 1996 was the first year for a fully electronic front axle disconnect from the previous thermal axle disconnect. It sounds like that or the wiring to it could be your culprit.
Click this link for the ultimate fix for front axle disconnect issues. http://www.4x4posi-lok.com/app_chevy-k.html
DirtyLarry is offline   Reply With Quote
