Old 11-23-2007, 09:53 PM   #1
timzrides
timzrides's Avatar
1988 trans cooler
Is a trans cooler needed for an 88 with 5.7. I bought project truck and i'm not sure what else is needed. I have the radiator in and thats it. does any body have a picture with out the grille on. thanks
timzrides is offline   Reply With Quote
Old 11-25-2007, 08:02 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 1988 trans cooler
If you have an automatic, you gotta have a cooler. If your radiator doens't have fittings, then you need an aftermarket cooler. My '96 Silverado had the towing packing, which included engine and transmission oil coolers. My '96 GMC, with V-6, doesn't have anything but the factory cooler, as equipped.
My '69 has an aftermarket cooler that I had to mount on the front side of the A/C condensor. The threads were dinged on the radiator, thanks to my own doing. I bought it at O'Reilly's and it has been trouble-free for the five years I have had it.
Member Nr. 2770
Old 11-25-2007, 09:48 AM   #3
timzrides
timzrides's Avatar
thanks
Old 12-08-2007, 08:22 PM   #4
71big block
1971 GMC 3/4 ton, 572 CID
71big block's Avatar
You need a radiator with a cooler, an axulary cooler won't cool enough, the fluid to fluid (water) cooler is much more effecent that a fluid to air. even if your coolant tep is 190 degrees it will cool the trans fluid, an axualiry cooler is just that, when you are putting extra load on the system it will help but don't ever run just a fluid to air cooler. you'll burn up your transmission expeschialy if it is a 700r4
71 GMC 3/4 572 CID,
1988 GMC 1/2
2006 Saturn Vue
"We always have parts left over on a job this size"
71big block is offline   Reply With Quote
Old 12-08-2007, 10:17 PM   #5
66skylarkpost
66skylarkpost's Avatar
well ,since my '89 c1500 is in finaly in the garage getting painted , i dont have the grille in it now . here's what i did , i think the cooler is a flexi-lite from summit .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
