Old 01-09-2003, 05:27 PM   #1
72MARIO
72MARIO's Avatar
what is this hole for?
Shaving my fire wall and I want to know what the holes I am filling in are for(were for). It is the round hole above the cas pedal cable. Its a 72 cab. Thanks If I knew the Image was that crappy I would have not posted it!!!
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-09-2003, 05:50 PM   #2
Alexis
Member since 2000
Alexis's Avatar
LMFAO........your a artisit, lol. it suppose to be for the level on a manuel transmission. let me go double check that.
edit: nope its a rubber gasket ot plate thingy that goes there and the oil pressure lien runs threw it.
edit agian: hehehe ok finally got it, it's the wire loom for the rear lights
Alexis is offline   Reply With Quote
Old 01-09-2003, 11:33 PM   #3
72MARIO
72MARIO's Avatar
thanks alot I will run the wire loom across the floor and out of the cab under the seat as for the oil pressure gauge I will run it up through the floor. Thanks for the help it took like 69 views to get a answer. Oh and if I could have removed the image I would have!!!
2005 TAHOE DD
