10-08-2007, 03:48 PM | #1 |
Best Power Door Locks
I've been thinking on going keyless on the truck. Who sells the best power door lock setup for the money?
1997 GMC Sierra Ext 1965 Mustang |
10-08-2007, 04:26 PM | #2 |
Licensed to Thrill!
Re: Best Power Door Locks
Without question...
http://www.a1electric.com/ Several on here have bought from them. They are some of the only actuators I have heard that reliably lift our stiff locks up and down. I have them on mine with a DEI alarm/keyless system. DLB |
10-08-2007, 04:32 PM | #3 |
Is this the kit your referring to for our trucks?
http://www.a1electric.com/Merchant2/...Code=W01-RF104
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-08-2007, 05:18 PM | #4 |
i used the one at lmc, with the remotes not just the actuators. works fine from 20 feet
10-08-2007, 05:21 PM | #5 |
Just want to make sure that the power actuators do have enough pull and push....
I have seen the ad for A1electric. Just need some feedback before getting.
10-08-2007, 05:27 PM | #6 | |
Licensed to Thrill!
I actually just used the 2-door lock kit, which is that same thing - minus the keyless entry they are offering. For the price, with the good actuators, and the DEI keyless system - this is a heck of a deal also. http://www.a1electric.com/Merchant2/...Code=W01F-712T This is what I have purchased from A1 Electric: http://www.a1electric.com/Merchant2/...Code=W02-RF104 (for my wife's car). http://www.a1electric.com/Merchant2/...duct_Code=W01F (for my truck). So I have used their setup with & without their keyless entry & with my own DEI Keyless entry system. I am a fan of the DEI system. Theirs is fine - but the DEI is better IMO (that is the keyless entry side of it only). As far as the locks go - they are top notch all the way. I couldn't ask for anything better. They slam my truck door locks up and down - have for over 2 years now I guess. DLB Last edited by Orange; 10-08-2007 at 05:34 PM. |
10-08-2007, 05:47 PM | #7 |
I used the 2 door lock kit from A1 too. It works great once you get it all adjusted correctly. It took a while for me to get mine working right.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
10-08-2007, 06:52 PM | #8 |
Was the wiring pretty much straight forward?
10-08-2007, 09:35 PM | #9 |
These look like standard actuators that have allot of drag when try to manually lock or unlock the doors! can anyone confirm if these are hard to raise and lower manually once installed? I prefer an upper end DEI actuator that has no drag!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-09-2007, 08:31 AM | #10 | |
Licensed to Thrill!
For the locks themselves, it was very straightforward. My alarm is the only thing that was complicated at all. Very simple otherwise.
DLB |
10-09-2007, 08:48 AM | #11 |
If anyone needs wiring help on this kind of stuff just let me know!
10-09-2007, 09:01 AM | #12 |
Professional Grade
I put a similar kit to the A1 stuff made by Audiovox (same looking actuators, except black and no remotes) into my 96 DD, and I've been nothing but impressed. Made locking and unlocking the door easier if anything, and has been reliable for almost a year already.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-09-2007, 10:13 AM | #13 |
Looks like it's going to be A1 then......
10-09-2007, 10:22 AM | #14 |
Self-proclaimed LED man
I bought a pair of actuators at a swap meet for $5. The guy said they were out of a 90's something chevy van, and they worked great. You'll have to drill two small holes behind the door panel, and weld an extension onto the pull knob. I went the keyless entry route also. Hid everything inside my center console. Let me tell you, its very handy
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
12-08-2007, 03:57 PM | #15 |
diggin this back up...
i see this kit and it says "This kit comes with the DEI 712T keyless entry system" would that be like the DEI system you're talking about? i can't wait to unlock my 40 yr old truck with a remote and see people scratch their head : D http://www.a1electric.com/Merchant2/...Code=W01F-712T |
12-08-2007, 04:30 PM | #16 |
1970 Daily Driver
I got my lock actuators at Napa 8 years ago for $10 each and one of their generic key less entry systems for $50. It worked great till about 6months ago when both key pads gave up, the actuators still work like new.
So now I put in a Autopage system made by Viper but way cheaper, I got it for $65. I still use my old actuators. Now I have key-less entry, remote start, remote window roll down and up, and a security system/Alarm. For the windows up and down I had to buy a special relay for $20 bucks. The only down side to this kit was that its directions were directed more for a professional installer. I was lucky to have a friend that had more experienced than I to help. It sounds like there are some on the board that could help though.If you are interested I will get the product numbers off of the boxes when I get home. It is worth it all of the way. It is great to see some one walk by the truck and watch their face as I start it up from across the parking lot, it is a pretty healthy running truck.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
12-08-2007, 09:41 PM | #17 |
i wish i could get remote start, but i have a manual, and i can just see me now, accidentally leaving it in gear and starting it in a busy parking lot... lol
12-09-2007, 12:16 AM | #18 | |
12-09-2007, 10:28 AM | #19 | |
Licensed to Thrill!
And yes - people are always grinning when I pop the locks on my '71 with a remote and it says "tweet tweet". DLB |
