Old 12-09-2007, 01:10 PM   #1
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: 4WD Won't engage, '96 K1500 Suburban
See if this helps chase after the P1860 code. Seems like a stretch to be related to the lack of front axle engagement or 4wd in general. I think you have two issues going on.
DTC P1860 TCC PWM Solenoid Circuit Electrical
Circuit Description
The Torque Converter Clutch Pulse Width Modulation Solenoid Valve (TCC PWM Sol. Valve) controls the fluid acting on the converter clutch valve. The converter clutch valve controls the TCC application and release. The solenoid attaches to the control valve body within the transmission. The solenoid receives ignition voltage through circuit 1020. The Vehicle Control Module (VCM) controls the solenoid by providing a ground path on circuit 418. Current flows through the solenoid coil according to the duty cycle (percentage of ON and OFF time). The TCC PWM Sol. Valve provides a smooth engagement of the TCC by operating during a duty cycle percent of ON time.
When the VCM detects a continuous open or short to ground in the TCC PWM Sol. Valve circuit or the TCC PWM Sol. Valve, then DTC P1860 sets. DTC P1860 is a type A DTC.
Conditions for Setting the DTC
• The system voltage is 10-16 volts.
• The engine speed is greater than 450 RPM for 5 seconds.
• Not in fuel cutoff.
• The VCM commands first gear.
• The TCC duty cycle is less than 10% or greater than 90%.
• All of the above conditions are met for 5 seconds and either of the following fail conditions occurs for 5 seconds:
- The VCM commands the solenoid ON (90%) and the voltage input remains high (B+).
- The VCM commands the solenoid OFF (0%) and the voltage input remains low (0 volt).
Action Taken When the DTC Sets
• The VCM illuminates the Malfunction Indicator Lamp (MIL).
• The VCM inhibits TCC engagement.
• The VCM inhibits 4th gear if the transmission is in hot mode.
• The VCM freezes shift adapts from being updated.
• DTC P1860 stores in VCM history.
Conditions for Clearing the MIL/DTC
The VCM turns OFF the MIL after three consecutive trips without a failure reported.
A scan tool can clear the DTC from the VCM history. The VCM clears the DTC from the VCM history if the vehicle completes 40 warm-up cycles without a failure reported.
The VCM cancels the DTC default actions when the fault no longer exists and the ignition is OFF long enough in order to power down the VCM.
Diagnostic Aids
• Inspect the wiring at the VCM, the transmission connector and all other circuit connecting points for the following conditions:
- A bent terminal
- A backed out terminal
- A damaged terminal
- Poor terminal tension
- A chafed wire
- A broken wire inside the insulation
- Moisture intrusion
- Corrosion
• When diagnosing for an intermittent short or open condition, massage the wiring harness while watching the test equipment for a change.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step tests for voltage to the solenoid.
This step tests the ability of the VCM and wiring to control the ground circuit.
This step tests the resistance of the TCC PWM Sol. Valve and the Automatic Transmission Wiring Harness Assembly (A/T Wiring Harness Assembly).
DTC P1860 Torque Converter Clutch Pulse Width Modulation Solenoid Valve Circuit - Electrical Step
Action
Value(s)
Yes
No
1
Was the Powertrain On-Board Diagnostic (OBD) System Check performed?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check (4.3L) or Powertrain On Board Diagnostic (OBD) System Check (5.0L, 5.7L) in Engine Controls
2
Install the Scan Tool .
With the engine OFF, turn the ignition switch to the RUN position.
Important: Before clearing the DTC(s), use the Scan Tool in order to record the Freeze Frame and Failure Records for reference. Using the Clear Info function will erase the stored Freeze Frame and Failure Records from the VCM.
Record the DTC Freeze Frame and Failure Records, then clear the DTC(s).
Are DTCs P0740, P0753, P0758 and P0785 also set?
Go to Step 3
Go to Step 4
3
Inspect the TRANS fuse.
If the fuse is open, inspect circuit 1020 (PNK), the solenoids and the A/T Wiring Harness Assembly for a short to ground. Repair the circuit, the solenoids and the harness if necessary.
Refer to General Electrical Diagnosis Procedures in Wiring Systems.
Did you find a short to ground condition?
Go to Step 15
Go to Step 4
4
Turn the ignition OFF.
Disconnect the transmission 20-way connector (additional DTCs may set).
Install J 39775 Jumper Harness on the engine side of the 20-way connector.
Connect a lest lamp from J 39775 Jumper Harness cavity E to ground. Refer to Automatic Transmission Inline Harness Connector End View .
Is the test lamp on?
Go to Step 6
Go to Step 5
5
Repair the open or short to ground in ignition feed circuit 1020 (PNK) to the TCC PWM Sol. Valve.
Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
Go to Step 15
6
Install the test lamp from cavity E to cavity U of the J 39775 Jumper Harness.
Using the transmission output control function on the Scan Tool , command the TCC PWM Sol. Valve ON and OFF three times.
Does the test lamp illuminate when the TCC PWM Sol. Valve is commanded ON, and turn OFF when commanded OFF?
Go to Step 8
Go to Step 7
7
Inspect circuit 418 (BRN) of the engine wiring harness for an open, short to ground or short to power condition. Refer to General Electrical Diagnosis Procedures in Wiring Systems.
Repair the circuit if necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find an open, short to ground or short to power condition?
Go to Step 15
Go to Step 9
8
Install the J 39775 Jumper Harness on the transmission side of the 20-way connector.
Using the J 39200 Digital Multimeter (DMM) and the J 35616-A Connector Test Adapter Kit, measure the resistance between terminal E and terminal U. Refer to Automatic Transmission Inline Harness Connector End View .
Is the resistance within the specified range?
10-15 ohms
Go to Step 11
Go to Step 10
9
Replace the VCM.
Refer to VCM Replacement/Programming (4.3L) or VCM Replacement/Programming (5.0L, 5.7L) in Engine Controls.
Is the replacement complete?
Go to Step 15
10
Disconnect the A/T Wiring Harness Assembly at the TCC PWM Sol. Valve.
Measure the resistance of the TCC PWM Sol. Valve.
10-15 ohms
Go to Step 13
Go to Step 14
11
Measure the resistance between terminal E and ground, and between terminal U and ground.
Are both readings greater than the specified value?
250 K ohms
Go to Diagnostic Aids
Go to Step 12
12
Measure the resistance between each of the component terminals and ground.
250 K ohms
Go to Step 13
Go to Step 14
13
Replace the A/T Wiring Harness Assembly.
Refer to Torque Converter Clutch Pulse Width Modulation (TCC PWM) Solenoid, TCC Solenoid, and Wiring Harness .
Go to Step 15
14
Replace the TCC PWM Sol. Valve.
Go to Step 15
15
In order to verify your repair, perform the following procedure:
Select DTC.
Select Clear Info.
Drive the vehicle in D4 with the TCC On. Ensure that the following conditions are met:
- The VCM commands the TCC PWM Sol. Valve ON, and the voltage input drops to zero.
- The VCM commands the TCC PWM Sol. Valve OFF, and the voltage input increases to B+.
- All conditions are met for 5 seconds.
Select Specific DTC.
Enter DTC P1860.
Has the test run and passed?
System OK
Go to Step 1
DirtyLarry is offline   Reply With Quote
Old 12-09-2007, 08:18 PM   #2
'72 Chevy Suburban
Chevy's Rock!
'72 Chevy Suburban's Avatar
Lots of good stuff there Larry! Thanks again...
John
'59 NAPCO Pickup
'70 K10 Pickup 350
'72 C20 Suburban 350 (MIA)
'57 Chieftain 455
'68 Firebird Convertible - 400
'68 Catalina Convertible - 400
'85 Vette
'72 Chevy Suburban is offline   Reply With Quote
