10-15-2006, 09:25 PM | #1 |
Cigarette Ligher Install
I have what looks like a new cigarette lighter but the last owner did not complete the wiring. There is a red wire that I assume goes to the lighter socket on the fuse panel. The blue wire has a male circular plug that is unclear where it should go. My guess would be that it needs to be changed to a female blade plug and put into the lamp blade on the fuse panel. And then there is a male blade coming off of the lighter with no wire. Is this a ground and if so where is the stock grounding location?
Thanks, Whit |
10-15-2006, 09:57 PM | #2 |
Re: Cigarette Ligher Install
There is no grounding wire just ignore the terminal for the ground. it grounds thru the dash. I am sorry but dont have any info on the blue wire.
Aaron |
10-15-2006, 10:57 PM | #3 |
Designated A-hole!
All you need is the red wire clipped to the back iirc. Don't know about a blue wire?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-15-2006, 11:08 PM | #4 |
You have a lighter made to fit anything. Red wire to fuse panel-blue wire is for grounding when mounted in plastic dashes. (hook red wire up and see if it works-if not ground blue with a screw to dash.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
10-18-2006, 08:42 PM | #5 |
what knocking sound?
I just got my cig lighter today. Yes, the blue wire is for the built in light. It needs to be connected to the fuse panel. As the others said, it is grounded through the steel in the dash when mounted.
12-09-2007, 03:48 PM | #6 |
Hate to resurrect this from the dead, but where does this blue wire attach to the fuse block?
Tks. sb
1969 C/10 swb, 350, powerglide (daily driver) 2005 CRV (wife's ride) |
12-09-2007, 04:11 PM | #7 |
The light is the blue wire. Kind of cheezy, I tossed mine. I don't remember the originals having this. I could be wrong but my truck is not stock so this is not that important to me.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
12-09-2007, 06:00 PM | #8 |
member #16
Look on the fuse box for a spade terminal for cluster feed. That will turn light on when light switch is turned on.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-09-2007, 06:33 PM | #9 |
i just splice the lamp wire into the lights on the heater control so as to limit the clutter at the fuse panel for a cleaner look// would also run a black wire from the empty lug to assure a better ground and working lighter as i've seen a number of aftermarket lighters that dont ground as good to the dash as the OEM lighters did
12-09-2007, 06:52 PM | #10 |
its all about the +6 inches
no clue why some did and some didn't, but the light in the lighter idea is a stock one. One of mine had it, and I've seen it on many others. As original it is a green wire for the light.
Plug it into the cluster feed, as mentioned above, and the light in the lighter will work with the dash lights. |
12-10-2007, 02:12 AM | #11 |
That is why they call you the board GURU
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
12-10-2007, 06:23 AM | #12 |
i learned about it right here.
