Old 12-10-2007, 09:36 PM   #1
willis0107
67lwb
willis0107's Avatar
Under Coating
Who ever the idiot was who decide that undercoating a vehicle was good is not on my good side right now. After finally getting the nuts and bolts off the frame and getting all the grease off I am now having to remove all the undercoating off the frame. A royal pain in the ass if you ask me.
willis0107 is offline   Reply With Quote
Old 12-10-2007, 09:43 PM   #2
brianthelion02
Overdrive club
brianthelion02's Avatar
Re: Under Coating
A p.i.t.a. for sure,but that may be why you have a good frame left to work with!!!!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 12-10-2007, 09:56 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Under Coating
I don't have to worry about anymore rust coming, because the bottom of my truck looks worse than the inside of an oil tanker...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-10-2007, 10:09 PM   #4
willis0107
67lwb
willis0107's Avatar
Re: Under Coating
for a california truck it was a waste of money to undercoat it. Heck I don't even undercoat vehicles in the midwest where they believe in SALT on the roads during the winter
Old 12-11-2007, 04:30 AM   #5
Cannon007
Re: Under Coating
As soon as suspension gets taken care of, undercoating is going on THICK! I dont care if its hard to take off, atleast the nuts and bolts wont be fuzed together from rust.
Cannon007 is offline   Reply With Quote
Old 12-11-2007, 06:19 AM   #6
cdowns
cdowns's Avatar
Re: Under Coating
using stainless fasteners solves that problem
Old 12-11-2007, 08:13 AM   #7
willis0107
67lwb
willis0107's Avatar
Re: Under Coating
all the undercoating does is hold in moisture. everyplace that there was a chip in it there is rust formations.
Old 12-11-2007, 11:45 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Under Coating
I agree with willis0107, in temperate climates where they don't use salt on the roads it's really not necessary. I like to see what condition the metal is at all times and a poorly installed undercoating will hide a lot of the rust if the metal wasn't prepared properly.
I have a thin layer on my 68 gmc under the fenders that I'm going to remove and recoat them with a good coat of POR 15 or similar.
68gmsee is offline   Reply With Quote
Old 12-11-2007, 12:28 PM   #9
c10addict
c10addict's Avatar
Re: Under Coating
living in Pa and always building cars I see a TON of under coating!!!! What I found that works great is get a spray bottle or bug sprayer and fill it with kerosene.. Spray some on in the morning then afternoon then evening.. DONT touch it.. Let it soak!! Repeat this process for 2 to 3 days then hit it with a scraper.. It will fall right off.... This is a really clean method... Alot of guys approach it woth a burnzomatic torch but man it stinks,makes a mess and when that stuff starts to melt off it always finds your skin....
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
