Throttle rod
Were can I get a new throttle rod for my 67?? I have a new 650 double pumper and the rod I have is bent up and looks like crap.
Re: Throttle rod
Designated A-hole!
Re: Throttle rod
I think your only option is to post a WTB on the parts board for a used one, I don't think these are being reproduced.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: Throttle rod
I found a couple. Iam going to make this one.
![]() Join Date: May 2005
Re: Throttle rod
Hey drbyrdman, make one for me too!!
Re: Throttle rod
I made mine. The stock one didnt fit my crooked carb...
Re: Throttle rod
Hey drbyrdman,
I was planning to do this a couple of years ago but had no luck finding any of the end links (they called Heim joints?). Do you know where they can be found? (for now I have the bent coat hanger version) |
![]() Join Date: Nov 2006
Re: Throttle rod
speedway motors sells heim joints and you dont need chrome moly one also....
bob
I BELIEVE IN JOHN 3:16 |
Broke and still trying
Re: Throttle rod
i went to the local OSH and bought female heims on both ends, threaded rod, jam nuts and the aluminum fuel line tubing to cover the threaded rod. DONE!
yes, i do
Re: Throttle rod
that looks nice. might have to make one for my 60 so i can use my gas pedal again. had to take out the pedal when i added the carb spacer so all i got is my rod for right now. there might be some aircraft parts that i can aquire for that........
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#11 | |
Re: Throttle rod
This is a good idea. I like using the fuel line to cover the threaded rod, nice finishing touch. The biggest problem with my throttle rod is that I had to weld an extention onto it and I don't like the fact that you can see the join .... with the fuel line the problem is resolved and looks good as well. esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
Re: Throttle rod
I made mine with heim joints and threaded rod also. I got my stuff from Lokar products. It would've been a little pricey, but I got a deal on some discontinued heim joints.
![]() www.lokar.com
Re: Throttle rod
Made mine a couple of months ago, found all the parts at napa, heim joints are also known as spherical rod ends.
Truck and auto performance nut
Re: Throttle rod
Mine doesn't have enough travel to completely open the Rochester 4V thats on mine. Any tricks to this? Or do I need to swithc to a cable setup?
If so, I'd sell you my throttle rod setup.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#15 |
Re: Throttle rod
I went to the hardware store and bought a piece of 1/4" fine threaded rod, a piece of brake line to cover it, and the parts store had the Heim joints. I could make some if anyone wants one. It works great!
#16 |
![]() Join Date: Aug 2004
Re: Throttle rod
Those spherical rod ends make the throttle so much more smooth than the original rod. Here's what I used:
http://www.bakerprecision.com/longacr53.htm It was so cheap and felt so much smoother that I'd do this to any mechanical throttle linkage. 68GMCCustom; you probably need to just shorten up your linkage. That should get you full throttle. I had to change the length on mine when I went from carb to TBI so I would still get wide-open.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
