O.k. Its time for cam and lifter set 376,000 miles original cam and lifters. I bought it in 1979 69,000 miles then . My question is I want it be be as stock as it always has been . What would be a good cam and lifter set and where to get it. thanks
Re: cam and lifters 350
I'd think you could get a stock grind cam & lifters from your local parts house...
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
with that amt of miles you'd need new springs and should also do a valve job then to prevent blowby a minimum of a hone and new rings really woudnt be a bad idea to turn the crank and new bearings etc etc etc you'll never het your moneys worth out of gettiung a new cam its pretty much an all or nothing deal with a ultrahighmileage motor
I agree with cdowns, just get the parts for a stock rebuild. A new cam and lifters only will snowball into an overhaul anyway, and this way you won't get stranded.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
I wouldn't crack open a 376K engine (?!) to replace a cam...
Heads have already been done about 20,000 miles ago. I have had a bad cam lobe for awhile just wanted to take care of that not a complete overhaul it uses very little oil and we checked piston walls during head job they looked great.These engines last forever driven correctly and taken care of . I have alot of confidence she will go 500,000 with cam and lifters.
The cam you're looking for is GM P/N 3896929; CompCams sells this cam under P/N 12-105-3. It may be available from others as well.
I'd certainly replace the timing chain as well "while you're in there". Last edited by Billla; 12-16-2007 at 12:15 PM. |
Yeah I will definitely add new timing chain and gear.Can cam be removed without grill out or not.
u can get it out by pulling your radiator, idk about gmc grills but 71 chevy grills are really easy to get out
70 Chevy C-10 short step 250/3 on the tree Owned: 71 longbed Cheyenne 70 swb |
i have a stock cam for sale (dont know the miles) but it looks to be in good shape let me know
71 Chevy
A real nice stock cam is the 300 HP 327 repacement cam. It is a great cam for what you are looking for and you can get a whole cam, lifter and timing set from nortern auto parts for about $60. I used that setup and they sorked perfect for a stock SBC cam setup.
71 C10 72 C20 62 Chevy II 2DR HT |
For passenger cars, same cam - GM 3896929. 65-67 used a slightly different cam, GM 3732798 with more intake lift (.398 vs. .390) but less exhaust lift (.398 vs. .410). Typically a non-dual-pattern cam gives a bit more torque at the expense of top-end HP. Do you have the specs on the cam you're getting from Northern?
I checked that Northern website Boot thats a very nice price. I checked local stores at least twice that much . thanks terry
![]() Join Date: Nov 2006
ii agree with billa, crate engine time........
I BELIEVE IN JOHN 3:16 |
#15 |
dont ask me i just flattened the he!! out a cam that i got with a whole top end kit i ordered from trick flow. already bought another one though, now i guess i get to do it twice. but i did shave and paint my firewall while i had it disassembled.
