Old 12-17-2007, 11:13 AM   #1
wibilly
wibilly's Avatar
power stearing upgrade
i know this musta been posted before but a quick search din't turn up a quick answer. i wanna put power stearing on my 69 c10. i have the compleate setup from ps box to outer ti rods all in one piece sitting on the garage floor from a 79 gmc 1/2 ton. what is the easiest way to do this? do i need just the box and pump or everything, thanks
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-17-2007, 12:00 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: power stearing upgrade
Bolt the box and pitman arm on. You don't need to change the whole steering linkage, just the pitman.
Install a power steering pump and brackets onto the engine. It depends on whether your truck uses short (original) or long (not original) water pump setup. You pump and brackets will need to match whatever your engine has.
Install the two lines between the box and pump, fill with fluid, bleed and enjoy.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-17-2007, 02:29 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I thought someone posted that you need to use the matching idler arm for the pump/pitman arm.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-17-2007, 03:40 PM   #4
Tx Firefighter
Nope, idler arms are the same, the only difference concerning the steering linkage is the pitman arm. Manual versus power steering use two different pitmans.
Old 12-18-2007, 01:34 PM   #5
I`m a pitman.
Old 12-18-2007, 01:43 PM   #6
wibilly
wibilly's Avatar
manual or power ?
