Old 12-17-2007, 06:01 PM   #26
AJs72K5
AJs72K5's Avatar
Re: Tried 20's on Green Monster
Originally Posted by Jtrux View Post
So when are you changing yours?
The whole suspension, axle, tire, and wheel setup is changing over the winter. The truck is up on stands right now as the work has already started.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 12-17-2007, 06:01 PM   #27
Critter
Future TOTM Winner
Critter's Avatar
I Love how the 15s look on your original truck Green Monster. I personally wouldn't do it. On the other, hand for a lifted, more customized K5 like AJ's the proportions look a lot better/more natural. Just my $0.02.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-18-2007, 01:28 AM   #28
Green Monster
Green Monster's Avatar
Agreed. The 15's look good. 17's look nice too. 18's are not offered in that style wheel otherwise I might consider them too. If I went to 35 inch tires the wheels would definitely have to go up in size too. The 33's just look too small to me but 35's look like they will give me clearance issues as the tire and fender will rub. Like most of you guys said... I'll just leave it alone. It looks good the way it is.
Green Monster is offline   Reply With Quote
Old 12-18-2007, 02:57 AM   #29
jaros44sr
jaros44sr's Avatar
GM, I am in the same situation. I like the looks of 35's but can't fit them under my truck without body damage and the fear of snapping an axle. Unsafe both ways. 35's seem to be proportional to the bulk of the truck...
Using a lever and a fulcrum as an example, the further out the lever you move the easier it is to lift. You could lift something in closer on the lever, but it would take more force, possilby snapping the lever (or axle). Could we take this logic and apply it to the ring and pinion? If I were to run 4.56 gears would that lessen the force on the axles, or is it just the mass, wt. of the wheel tire combo that is the culprit. Seems to me, you wouldn't be applying as much force with the lower gears.
I'll probably get flamed for saying this, but there has to be a way I can safely run 35's on the street w/4" of lift and not cause anyone harm, my truck and self included. I just don't know what is snapping axles
I like the way yours looks with the 33's...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-18-2007, 03:35 AM   #30
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
I agree...when you go up to 35's, then the 17's look good, but I think you would have to go to 40's or even bigger to make the 20's look correct. Obviously this is just my opinion and your's is the one that counts.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 12-18-2007, 03:51 AM   #31
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
You mentioned 15' and 35's so here that is, as for the 20's I say no
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-18-2007, 04:57 AM   #32
Green Monster
I figure this:
33" tires go with 15" wheels.
35" tires go with 17" wheels.
Just my opinion.
I'm already committed to the 15" wheels so I'll stay with the 33" tires. I purchased a new matching spare 15" Weld Racing Super Single II wheel last month as a Christmas gift to myself to mount a spare 33" Mud Terrain tire. It may take a little getting used to but I think it should look better than a skinny spare with a vinyl cover on it.
Last month I removed my roll bar and took it to the body shop to strip, paint and clear with PPG paint. It turned out really nice looking. No more scratches and gouges. I showed the guys at the shop how I want the spare tire carrier modified so it can hold the new wheel and 33" tire. They looked at it and said it will be an easy modification. I'm looking forward to the spring already...
Old 12-18-2007, 05:06 AM   #33
Chevyman63
Chevyman63's Avatar
That sounds cool! I wish I were that close to being done. Hey, if VT and Jaros44 head my way this coming summer, maybe you would like to join them? Sounds like a good time.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 12-18-2007, 05:57 AM   #34
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Generally, 35's are considered to be the top end of what is "safe" on 1/2 ton axles. Unless you are going to be wheeling it hard, your chances of snapping an axle are fairly slim. The gearing probably won't change the strain on the axles, but the strain on the engine. 4.10's are about right for 35's on the street. A 4" lift works with 35's but you may have rubbing if you wheel it. 6" lift is better. Of course, wheel size and off-set come into play on clearances and strain on the axles.
I've had two K5's with 35" tires on 1/2 ton suspension. One had a 4" lift the other a 6". The truck with the smaller lift was running 3.73 gears, which wasn't quite low enough. The other was running 4.10's which gave it a lot more get-up-and-go.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-18-2007, 06:19 AM   #35
jaros44sr
jaros44sr's Avatar
Thanks for the explanation, makes sense. I don't plan on wheeling hard, just getting to the campsite and green trails. But, I do plan on putting it on the beach. Could be a very bad time to snap an axle with the tide coming in. I better mount a winch
SAFETY FIRST
AS usual, off topic
Jim
Old 12-18-2007, 07:56 AM   #36
BLUE THUNDER
BLUE THUNDER's Avatar
IMO, 15's or 16's max. Big wheels might be in these days, but not on a classic Blazer. Just doesn't look right. Mario
BLUE THUNDER is offline   Reply With Quote
Old 12-18-2007, 10:52 AM   #37
ABLAZN
Oh..never mind....
ABLAZN's Avatar
I agree with you to a point. I really like some side wall on our rigs, not mention any 4X4. I really had to think hard before going to 17's, but with my 35's, they like right. It really was not much of a stretch though, since "back in the day" we would run 33's on 16.5 rims and that looked good too. One of the reasons I made the switch to 17's is that tires are getting harder to find in 15's. The newer rigs are using 16 and bigger more and more stock, so I just wanted to be able to get tires with out special ordering a set when the time come to replace them again.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 12-18-2007, 12:53 PM   #38
vtblazer
vtblazer's Avatar
The wheel/tire combo makes a statement, both about the owner and what he thinks/wants the truck to come off as.
15" wheels & 33" tires with a 4" lift has a very classic/beefy look IMO.
Anything past that and your getting into either bling or redneck territory.
Chevyman63, what'd ya mean "if"?
Yeah, GM deffinetly needs to jump in on this road trip!
vtblazer is offline   Reply With Quote
Old 12-18-2007, 01:31 PM   #39
CG
BlahBlahBlah
I like the 15's. I dont care for the large diameter wheels on any 4x4 much less a classic blazer like yours. My eye needs to see a pretty good sidewall on any 4x4. Im not sure what it is...maybe its too much body mass hanging over a small sidewall that looks off to me.
But heck Im just coming around to liking the bigger wheels on lowered trucks...what do I know?
Old 12-18-2007, 01:57 PM   #40
1969k10stepside
I'd stick with the 15s if the only other option was 20s but a 16 or 17 inch rim isn't bad.I've got 16s on my 71 K10 with 35" tires..As for clearance if you would go to 35s....With a 3" lift you might run into issues with the front tires hitting the fender cups....I'd run 35s on the current 15" rims though if the 35s would fit..
Here's my 16" rims and 35s:
1969k10stepside is offline   Reply With Quote
Old 12-18-2007, 02:40 PM   #41
Kurt L
Kurt L's Avatar
don't touch a thing 15's are great lookintg on your truck.btw beautiful blazer you have
Kurt L is offline   Reply With Quote
Old 12-18-2007, 04:40 PM   #42
Green Monster
Thanks for the compliments. I need more details about the Michigan trip to Chevyman's. When is it? What is it for? Are you taking the Blazers? I don't do rain in the Blazer. So that makes me a last minute, probably not because of t-storms if we're taking the Blazers. I appreciate the invite but I need more info about it.
I'll stick with the 33's on 15's even though they are starting to look wimpy to me. From what some are writing, it has a classic look to it. So I'll keep it. I just want a stock looking Blazer with a nice lift, wheels, tires, low end torque and a nice sounding exhaust. I have all that so I really should not be messing with anything. Especially if messing with something is going to cost me a few thousand dollars. Considering the paint job I want will cost me at least $10-15K. I should really save my money for that.
Funny 69 Stepside posted those Pro-Comp tires. I'm considering purchasing a set of Mud Terrain Xtreme based on what I read on this car domain page. Link
They are stated to be quieter on the road and have sipes for rain... oh that's right, I don't do rain. Anyway. Anyone know anything about these Pro-Comp tires? Are they better than the BF Goodrich Mud Terrains? I am on the fence about these. The BFG's do have a distinct look about them.
Old 12-18-2007, 05:26 PM   #43
billyjo
Junior Member
billyjo's Avatar
Here is a pic with 35's and 17's
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's.....
http://s72.photobucket.com/albums/i1...tos/?start=all
billyjo is offline   Reply With Quote
Old 12-18-2007, 07:24 PM   #44
Big J
Its lookin' like a Blazer!
Big J's Avatar
I like them all..... It all depends on what the rig looks like and what wheel/tire combo. What looks awesome on one, may look like crap on the other. 15-20s, its all good.
billyjo, is that your ride? Looks sweet, kind of a modern classic.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 12-19-2007, 02:39 AM   #45
Green Monster
Billyjo: Do you have any issue with rubbing the fender cups? I saw a video you posted sometime last year in the snow. That is one bad a$$ Blazer. The supercharger whine was incredible. Very nice ride indeed.
Old 12-19-2007, 03:34 AM   #46
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I couldn't agree more.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-19-2007, 04:00 AM   #47
billyjo
Junior Member
billyjo's Avatar
Yes that one is mine, thanks for the compliments.
The only place that mine ever rubbed was on the front of the rear wheel well. I added the ORD add a leafs and moved the axle forward an inch so that the wheel was more centered in the well and haven't rubbed since. I do have 1 ton running gear and I think that adds a little to my original lift also.
Old 12-19-2007, 04:51 AM   #48
Tynee
I miss this truck.
Tynee's Avatar
Hey Green Monster, if you do get new wheels, are you going to send the updated photos to the ebay scammer who's been using the photos of your truck?
If I ever meet that guy, I'm gonna kick him square in the sac. (didn't we used to have a smiley for that?) Every time I see GM go up on eBay, I start looking for places to sell a kidney, just in case its for real this time. My realtor is getting sick of me putting my house on the market and taking it off, too.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 12-19-2007, 06:03 AM   #49
N2TRUX
Happy to be here
N2TRUX's Avatar
You might like the 20's better if you had proportioned them correctly in your PS. Personally I think 15's on anything bigger than a 33 look too small.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-19-2007, 10:21 AM   #50
Green Monster
I could not proportion the wheels any more accurately (correctly).
I figured I want to put 20's on using a picture of 15's. I took 20 and divided it by 15 which results in 1.33 repeating. Converted to percentage this equates to 133%. So a 20 inch wheel is 133% larger in diameter than a 15 inch wheel.
I placed the photo into MS Paint, cropped the wheels and stretched them by the multiplier of 133% vertically and horizontally resulting in a perfectly proportioned 20 inch wheel. Then I just touched up the corners of the cropped wheel. Is there a more accurate way to correctly depict 20 inch wheels in my photo?
