Old 12-15-2007, 04:38 AM   #1
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Gasket???
Hay, good morning! Does anyone know the part # for a Felpro gasket. I am looking for the blue one piece, dry seal, oil pan gasket. It comes with bolts. The one I want is for an 85 350. There are 3 for the small block that I know of. The difference is the dipstick hole.
Gasket 1 has dipstick on passenger side. Part # O?????T
Gasket 2 has dipstick on driver side. Part # O34509T (I think that is what I saw last night, we were closing up)
Gasket 3 has dipstick holes on both sides. (universal) Part # O34510T (if i remember corectly) this i have
I need the part # for gasket 1.
I know someone out there knows this. I have seen all three in my hand. I work for a parts store. (Part Time 2nd Job)Can't remember
LOW DOUGH is offline   Reply With Quote
Old 12-15-2007, 06:08 AM   #2
Slammed70
Slammed70's Avatar
Re: Gasket???
I think what you are looking for is the Permatorque. #OS34510T
Its one peice...and even comes with fastners to boot.
Photo is illegally bootlegged from Summitracing.com
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-15-2007, 06:38 AM   #3
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
that is the one i have. I am looking fot the one with the dipstick on one side. The passenger side that is. I have found the one on the driver but that is for an older V8. We're going in the right direction. I know some one knows this
Old 12-15-2007, 07:13 AM   #4
Ole Blue 68
Ole Blue 68's Avatar
Re: Gasket???
Only one I found....
OS34500R- Fits 86-99 SBC
Ole Blue 68 is offline   Reply With Quote
Old 12-15-2007, 08:21 AM   #5
Slammed70
Slammed70's Avatar
Re: Gasket???
Why not just use a stocker then?
This is the stock, one peice for 87-99 SBCs.
Photo used again without permission from Summitracing.com
Old 12-15-2007, 08:55 AM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
i have an 85 block. 87 -99 wont work... the rear main is different
Old 12-15-2007, 09:00 AM   #7
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Re: Gasket???
Os34500r, But For 1pc Rr Main
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 12-15-2007, 09:00 AM   #8
Slammed70
Slammed70's Avatar
Re: Gasket???
How the hell do you have the dipstick on the right side then? They didnt start doing that **** till 87 with the new style block.
Old 12-15-2007, 09:04 AM   #9
Firefighter
Re: Gasket???
Victor # Os30568rrh Is The One. Fel- Pro Only Os34509t 1957-1974, Os34510t 1975-1985
Yellville, Ar. USA
Old 12-15-2007, 09:56 AM   #10
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
73 74 75 or something like that the dipstick changed sides. That's how you can tell if a motor is realy an old one from these trucks or an old car. I forget what year it was changed. Before 75 or so it's on the pass side after 75 or so it's on the driver side
Old 12-15-2007, 09:57 AM   #11
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
Thanks, i will have to check these part #'s out at my store
Old 12-15-2007, 11:10 AM   #12
dave2953
Dave's not here, man
dave2953's Avatar
Re: Gasket???
The one I just bought from NAPA for my truck was an OS34500R, and my dipstick is on the right side of the motor ('86 305). Make sure the one that you get is blue. Autozone sold me a gasket that they claimed was Felpro, but it was orange. It even had the same part number as the Felpro, but it was a piece of crap knock-off that leaked like crazy; sucks doing it twice.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-15-2007, 11:25 AM   #13
jaros44sr
jaros44sr's Avatar
Re: Gasket???
Maybe another consideration is the timing chain cover, I had to get a thick lip for my alum. cover on my one pc. But maybe you are running a stock one
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-16-2007, 04:51 AM   #14
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
This is atempt # 6 for me. It will not stop leaking. I just got a brand new oil pan. I hope that is what it was. Now i just need the gasket. I used the universal one last time. One with both dip holes.
I also put this up in the 73+ side and was given the same gasket. OS34500R I will look at this tonight at work.
Old 12-16-2007, 06:26 AM   #15
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Gasket???
I believe its 80 and newer is passenger side dipstick 79 and older driver side. 80-85 is two piece rear main. 86 and up are one piece rear main seal. Then there is also the thin and thick front seal but I'm not sure about that. You will need to have the oil pan and timing chain cover matched up. You can measure the distance of the lip on the oil in the center. Someone else might be able to help better on that part.
Did you silicone where the timing cover and block meet. Or the rear the rear main cap and block? Just like the four corners on the block before you install the intake gaskets.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-16-2007, 06:51 AM   #16
Ole Blue 68
Re: Gasket???
Might be the pan. I bought a brand new steel pan from Summit last year and try as we might, we couldn't get that thing to stop leaking. Tried an old pan that was laying around my friend's shop out of desperation and no more problems.
Old 12-16-2007, 07:58 AM   #17
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
Yeah i put sealer in all four corners. It come out of the front. I just got my brand new pan yesterday and will bring it to work tonight and try some out.
I do have a junck yard timming cover. I am wanting to get a brand new timming cover to. Then it will all be fresh and new.
Old 12-16-2007, 08:02 AM   #18
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
Originally Posted by Ole Blue 68 View Post
Might be the pan.
Yeah that is what i am thinking. I have taken this motor out 5 or 6 times and used the same pan every time. This pan that is on it right now was floating around the bed of my truck for a year or so along with all the other junk i had back there. It was my DD so it is probably bent a little were you can't tell. It leaks out of the front. But the balancer doesn't have oil on it so it has to be the pan. I have done everything else to fix it with no luck. I would say it has been leaking for 5 or 6 years OMG! One quart every other day when it was the DD
Old 12-16-2007, 11:50 AM   #19
Ole Blue 68
Re: Gasket???
Could also be the rear main seal. When they leak it can look like it's coming from the pan.
Old 12-16-2007, 12:37 PM   #20
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
IT is definitely coming from the front. It gets blown all down the pass. side of motor. Have no wheel wells in so it gets all over the right front disc. After driving hard it smokes and people tell me my truck is on fire. Nope it's not.... But close
Old 12-16-2007, 12:52 PM   #21
webfoot
Re: Gasket???
There are 2 different size gaskets for different oil pans, one has a thicker front seal and another uses a thin front seal. The difference is in the distance from the rail of the oil pan and the lowest part of the curve from the front seal.
If you bought a different oil pan, it may be the old style which requires a thin seal. Best way is to measure.
Here is a link, it is hard to read but maybe you can zoom in.
http://books.google.com/books?id=GUC...CaEj5ttV-drmsU
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 12-19-2007, 05:49 AM   #22
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
thanks Webfoot. I know about the 2 sizes. I am prity sure i have the right thing. But of course i am going to check.
anyone ever used this?
Old 12-19-2007, 07:40 AM   #23
60-66 Nut
Professional Beer Tester
Re: Gasket???
LOW DOUGH, you might check to be sure you are not missing the short 3/8" bolt that goes in one of the holes on the front passenger side of the block. One of these holes(I think the top one) is drilled into the crankcase directly in line with the fuel pump push rod. Some people pull that bolt out and stick a longer one in there to hold the push rod up while changing the fuel pump. I've run across a couple leaking there before. It would only leak when you drove it, not just sitting there. Just a thought.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 12-19-2007, 08:27 AM   #24
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Gasket???
60-66 Nut
HMMMMMMMMMMM..... ya no what? I don't have a bolt in there. I have an electric pump too. Hmm i am going to put a bolt in there and see what happens. I was woundering about that. I thought it was posible that that hole went all the way threw
