Old 01-11-2003, 02:51 AM   #1
72C10chevy4x4
UK Wildcat Fan!
how do I remove windshield wipers?
I have officially begun my ground up resto- pulled the hood/fenders/inners off tonight (it was a three beer job) but couldn't get the wipers off. How do I get them off? I saw a little tab but the wiper didn't budge when I messed w/ the tab.
thanks,
Paul
72C10chevy4x4 is offline   Reply With Quote
Old 01-11-2003, 03:08 AM   #2
zyggy72
Can't kick the addiction!
The wipers are press fit on. If you don't care much about a couple of scratches in the paint around either side of each wiper, I would suggest using the "L" shaped end of a small pry bar or the claws of a hammer to work the wiper arms off. Don't pry too hard, you may bend the cowl slightly, just pry from side to side on each wiper, they should come off.
zyggy72 is offline   Reply With Quote
Old 01-11-2003, 03:20 AM   #3
~72'Pete~
~72'Pete~'s Avatar
NOOOOOOOOOOOOOOO
You have to pull the tab first!!!!!!!!!!!!! The guy above used force obviously. Use a small screwdriver to pull the tabs COMPLETELY out then the wipers will come off straight away (it taks some force) I am assuming with the guy above somebody had already removed the windshied wipers and didnt replace the tabs. Trust me the little tabs WILL come out. Take your time and do it right, youll be happier then just using brute force
~72~Pete
~72'Pete~ is offline   Reply With Quote
Old 01-11-2003, 03:31 AM   #4
zyggy72
Sorry, none of the trucks that I have or have worked on had any type of tab to remove. So that was how I understood how to take the wipers off.
Old 01-11-2003, 04:50 AM   #5
~72'Pete~
~72'Pete~'s Avatar
Ziggy, please dont take my post as an insult, im been drinking,and should of worded it better.............im just a dunbass.
Sorry Bro
Pete
Old 01-11-2003, 05:14 AM   #6
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
DUNBASS????
fish on the grill???
the tab trick should be correct, just pop them out with a small screw driver, careful though....if I remember corectly those little clips will fly out and get lost quick. the wipers should just take a nudge or to to pull off after that.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 01-11-2003, 09:28 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Whoa, folks. I don't recall any "tabs" on my wipers.
What you have to do is to pry them off of the wiper shafts. There is a tool made specifically for that. It has two flat pieces on the end of the plier-type handles, and when you insert it between the bottom of the wiper and the cowl, you squeeze the handles and the wiper pops off. The tool is less than $10 bucks and it works.
There ain't no tabs on these trucks. The 88 and up.....well, THEY have tabs.
Member Nr. 2770
Old 01-11-2003, 10:19 AM   #8
Gene
Gene's Avatar
I'm with chevloray, I have had 7 of these trucks and have never seen any of these "tabs?" Could anyone post a pic of them? I have always pryed mine off by placing a rag under a prybar and then easing(not using brute force) them off. And I have never heard any clips pop out?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 01-11-2003, 10:30 AM   #9
72C10chevy4x4
UK Wildcat Fan!
I tried pressing the tabs up and down, couldn't do anything witht he wiper though-I wasn't applying too much force to the wiper b/c I guessed they would come off easier. thanks for the replys guys. my wiper arms have 'trico' on them, is it possible some fo the aftermarket wiper arms have tabs and others don't?
Old 01-11-2003, 10:42 AM   #10
teeitup
Just like to part out trucks!!
teeitup's Avatar
I've seen them both ways some have tabs and some don't. I think the ones without tabs may have been broke off already.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-11-2003, 11:51 AM   #11
greasemonkey
greasemonkey's Avatar
Mine don't have tabs, I just wrap a big screwdriver in a rag and lever the arm off.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 01-11-2003, 12:02 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Trico??? You are trying to get the wipers off of the arms, aren't you??
You don't need to remove the wiper blades from the arms. You just need to remove the wiper arms from the shafts. I told you how in my earlier post.
As far as changing blades, well, that depends on which refills you have (you said Trico). I have ANCO. Makes no biggee. IF you are planning to do a restoration, you are a loooooooooooong way from needing blades OR refills. Just get/borrow/buy the tool that I described above and remove the arms.
Member Nr. 2770
Old 01-11-2003, 08:13 PM   #13
SWINGSAX68
SWINGSAX68's Avatar
Talking Anco.....Trico????
Man wipers have names....then mine are "Don't no"
LOL
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
