Old 01-10-2003, 06:35 PM   #1
~72'Pete~
~72'Pete~'s Avatar
Back wheel locking up.new brakes?
My back wheel (drivers side is locking up very easily) locks up and I am not sure why, Ima newbie when it comes to this stuff.
I want to do a brake job, does anyone sell kits? What brand of parts do you guys use and reccomend.
Thanks ~72~ Pete
~72'Pete~ is offline   Reply With Quote
Old 01-10-2003, 07:36 PM   #2
vcrazy8
I would check to see if the wheel cylinder is leaking if it is you need to replace the shoes too
72 Custom Deluxe, Viper red with a 383 HT
vcrazy8 is offline   Reply With Quote
Old 01-10-2003, 09:42 PM   #3
Mike C
Mike C's Avatar
A leaky axle seal can make that happen also. Bottom line is you are going to have to pull it apart and inspect it.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-10-2003, 09:58 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
Yup...when mine did it, it was wheel cylinders.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 01-11-2003, 10:14 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Next time you notice it locking up, pull over and feel the wheel/drum carefully. If it's very hot, you have a brake locking up most likely due to a bad emergency brake cable.
I've had this on my truck and a Blazer I used to own.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-11-2003, 10:21 AM   #6
Gene
Gene's Avatar
Yep, i'd say leaking wheel cylinder. I had that same problem and found a bad wheel cylinder...
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
