![]() Join Date: Apr 2005
Pictures needed....
I need some pictures of the rear brake line routing and connections for 3/4 T truck or suburban. Thanks in advance.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
its all about the +6 inches
Re: Pictures needed....
you talking along the frame, or off the master... or all of it? Also, what year you interested in here?
Where the hard line connects to the rubber line that goes to the rear axle.
![]() Join Date: Aug 2003
What model frame is it? The 72's usually mount in a different location.
#5 | |
![]() R
Should be pretty close to a 1/2 ton setup other than the different style rear ends. Here is a Dana and an Eaton.
Few more.
Cool. 1/2 T hard line ends on the frame just prior to the rear axle.
Maybe on a 71,but these were both 72's. That's the main difference. The 72 line ran over and came out right above the chunk.
Would you happen to have the bracket that they union block and the rear rubber hose bolt to? Thanks,
Are you talking about the one in the pics?
That's on an Eaton rear. What are you using? There may be a difference in the line sizes. I'm sure I have one around here somewhere.
I have a 12 bolt. All I need is the bracket that bolts to the rearend, not the rubber hose.
#15 |
I'll try to get my hands on one Monday.
#16 |
Bump.
