Old member
Speedo Cable
OK,
I need a longer cable and housing. I need about 6" more to make it right. The old one is in to much of a bind and it jumps when going slower than 20 MPH. Would like to find one longer. New if possible. Junk truck or car.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() ![]() Join Date: Jul 2002
Re: Speedo Cable
They had several lengths at Advanced Auto/AutoZone (forgot which one I bought at) when I replaced the one on my 70. I just bought the longest one and it was about 6" or so more that the original cable.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-20-2007 at 12:44 PM. |
Old member
Re: Speedo Cable
Did it come with the outer sleeve that screw's on to the transmission and back side of speedo.
Re: Speedo Cable
bring your old cable(inner and outer) in to the autoparts store with you so you get the right replacement// i have better luck and i think better quality at NAPA and carquest
Old member
Re: Speedo Cable
Thanks,
I will have to try the local NAPA this weekend.
Re: Speedo Cable
Yes they came with the correct ends. Mine was AutoZone part# (CA-3004)
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-20-2007 at 05:42 PM. |
![]() Join Date: Nov 2006
Re: Speedo Cable
just pull out the inner cable, grease it up with white grease as you re-install it and it wont bounce anymore. its DRY......
I BELIEVE IN JOHN 3:16 |
Re: Speedo Cable
Any speed shop can make you a custom cable.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
Re: Speedo Cable
you should not need a custom cable if truck is not modified.
![]() Join Date: Oct 2005
Re: Speedo Cable
speedo attachment on the 700r4 is a little farther back. I had the same problem....just get 4x4 speedo cable...it's a number of inches longer.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Old member
Re: Speedo Cable
Thanks guy's, that's the problem SactoJim,
700-R4 has it streched to the limit and it bounces at the lower end. 20 MPH or less. 4x4 cable Kool! BCOWANWHEELS, Done that it helps but it still bounces.
