anyone have more than 2 fuel tanks?
My truck was plumbed for a third tank that must have sat in the bed, the fuel line and filter run up in the forward corner. I want to put a third tank back in but all the ones I see in catologs say not for gasoline. Are there any ideas of a how or where to mount another tank? I was thinking of finding one that sits in between the frame rails towards the rear since I dont run a spare tire under the bed I have the room.
Ed U.S. Coast Guard BMC (retired) |
1962 C-10
Re: anyone have more than 2 fuel tanks?
How about a Suburban or Blazer tank? Will that work?
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
thats what I was thinking too. I would be able to use the sending unit from it too.
I'd go with a Suburban or Blazer tank and move the spare to the bed. Having the sending unit hooked up would make it a true third tank.
Wishin' I had more money!
I'm not trying to knock you or your idea at all, but why a 3rd tank? What's the point?
#6 | |
Dirteh Kitteh
A third 20-25 gallon tank would almost double the range between having to stop for go-go juice when driving across North Dakota or Minnesota (which can be rather unfriendly at this time of year due to freezing body parts off in -60* wind chill weather).
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD ![]() ![]() RIP ESLL |
#7 | |
#8 | |
Professional Grade
I put a 43 gallon Suburban tank between the rails on my truck. The install is really easy, less figuring out a way to run the filler neck...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
what year suburban had a tank that big that would be perfect
Professional Grade
Mine is out of a 91
Workaholic
My '91 is a 40 gallon and all the replacement info I can find lists 31 or 40 gallon. Was the 43 a Canada only option? Just wondering. . .
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
#15 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
The biggest you can fit in a SWB is the 31 gallon tank. Here is my how to page for the Blazer in a SWB pickup..
http://www.captkaoscustoms.com/blazertank.html
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#16 |
My truck is an alcoholic
Been thinkin about stuffin a couple more under there, mainly because the still will be up and running next spring. Takes roughly twice as much alky to go the same distance as gas, best part is it will be super cheap!
some pics of the filler with the big tank would be nice. |
#17 |
Kind of an off the wall thought, but something I've been kicking around. How about a combo gas tank/truck box? Northern tool has a 51 and a 60 gallon model. Just a thought.........
#18 |
I looked at allot of catologs for them and just about everyone says not for transporting gasoline. Not sure why. The only bad part about that for me is I plan on running a cap on the back at times and it would make it hard to fill.
#19 |
Yeah, I was wondering that too. Northern's 51 and 60 say ok for gas, just not california gas. The 70 gallon says for fuel oil, but not gas. Huh? You're right though, it'd be kind of silly with a cap.
#20 |
One shot, one kill.
Guys: The reason the aftermarket tanks say "not for fuel" is for 2 reasons. 1 is saftey, the other is emmisions. I say go ahead and use them for whatever you please, but here's a thought, why not go to your local friendly heavy truck dealer with all the measurements you can think of and see if you can't come up with a tank for a motorhome chassis. Those tanks hold between 80 and 100 gallons. Yup, $325 will fill ya right up. LOL, jim
